Originally Posted by rcaudwell Do you have any experience of 7W in Merseyside? Struggling with 1.1m Triax, no signal on these frequencies - just wondering if it`s worth trying to tweak dish or if I`m wasting my time. |
Well, we've installed enough motorised 90s/ 1ms / 1.1s around there & the Wirral/ N Wales/ N/W Cheshire & further north etc... that a 'properly' installed 1.1 should really deliver 500+ channels & some [small] rain margin... unless you are in a black spot we don't know about yet &/or have a local interference problem [just takes one poor stage of an install &/or a street lamp in the wrong place].
So yes, you should & well worth the effort & the only reason on the arc to have a 1.1 .... loads of fta movies, not just the iffy 55555 TV movies channel & the 2 month old screeners they put on & JSC's got more on the way including more HD. [wonder if 55555 company will bung on FTA live EPL next
But this isn't 7w now really .. it's more the new stronger 7.3w position Atlantic Bird 7 [aka Nilesat 104] which is ....
a) about 20%- 25% stronger than Nilesat 101/102 stronger verticals 'were' before AB7 lit up and
b) has far more channels right through KU band & both pol's of about that power [+/- 10%] than 101/102 which had progressively harder tps through vertical & then horizontal and
c) seems to carry up country far better than Nilesat 101/102 used to & certainly doesn't drop off the same at Mid/ N Manchester like they did.
Nilesat 101/102 strong verticals have gone harder with what looks like bleed over interference from the more powerful Atlantic Bird 7 .. mainly it's the MBC movie channels on there now after Dubai's channels moved to 201, but they are on the easier 26e BADR4.
