Alternative ways to watch F1 from next year
Old 07-08-2011, 8:36 PM   #91
Thanks: Gave 20, Got 1
Thanks all, I had thought about manual switches, but I read somewhere about a 6dB loss. However, checked my Freesat signal strength on the Panny, and its very high, so should be OK. I'll get some shotgun cable, and run it along the path of the single core coax down to the lounge. As it happens, the cable comes in just behind the sofa, so quite a nice place to put a switch. This means I don't have to run a new cable under the carpet, the existing single will do. All I need to do now is decide on dish size, and if I need a signal strength meter to help line it up. I'm tempted to go for another standard Sky one as it will look better next to the existing one, but if the signal is weaker, and the switch takes some if it away, maybe a Zone 2 Sky dish or larger round one would be better. Are there any websites that may give me an idea of signal strength? Must say though, looking at the cost of new dishes off that big website that shares its name with a south American river, this upgrade isn't going to cost much, and I can always add a set top receiver at a later date for more functions.
Old 07-08-2011, 8:55 PM   #92
Ghostleader's Avatar
Thanks: Gave 31, Got 241
If your talking about a A-B push button manual switch then those figures are wrong mate, the loss is very little (Less than on a average DiSEqC switch).
PanMan (07-08-2011)
Old 07-08-2011, 11:02 PM   #93
Thanks: Gave 1,859, Got 4,224
Yes, you can easily switch the TV's source from one satellite to another, and 19 is strong so all you need for the second dish is one the same as you already have for 28. That's easy enough to align and as you say it won't cost much.
Old 08-08-2011, 12:20 AM   #94
Thanks: Gave 22, Got 1,053
I thought that I had read somewhere that yes the Panasonic can be used on different satellites but only one at a time - i.e. you can scan 28 E but when you try to scan say 19.2 it will then wipe the channels it had found on 28 E. Has anyone yet tried this and actually achieved it?
Old 08-08-2011, 10:12 AM   #95
Reading this thread Panasonic TXLl37V20B Sat reception problems!!! I think it keeps the channels looking at the last post. Anyway, I'll order the new dish today, manual switch and sat finder meter, so should find out soon!
Old 08-08-2011, 2:22 PM   #96
I have to say that using a TV for multi-satellite reception seems an odd way to do it but the results will be interesting if you report them.
Old 11-08-2011, 2:00 PM   #97
Can I just check something please, before I potentially make a big mistake! My existing dish (Dish 1) is connected by two feeds to a Sky + box, a single feed to an old Pace Sky box (Free Sat From Sky) and finally a single feed to My Panasonic TV with built in freesat for BBC HD etc. I'm fitting a new dish (Dish 2) for Astra 19, which will also be connected to me Panasonic TV via a manual switch here: Aerial Switch : Aerial Splitters : Maplin. I just want to check that its safe to connect both dishs to the Panasonic by this switch. I know LNBs are powered, so I don't want to damage anything by making a simple error and overloading the TV/LNB or anything like that. I have drawn a diagram to explain (MS is the manual switch mentioned previously), can someone please confirm that its all OK before I start?
Old 11-08-2011, 2:39 PM   #98
Yes, that's what the switch is for. It doesn't affect the other three connections to the Sky dish at all.
PanMan (11-08-2011)
Old 31-08-2011, 6:01 PM   #99
Thanks: Gave 36, Got 84
Hi, anyone know if the £40 Aldi system currently available is suitable for RTL F1 coverage and if it produces reasonable pic quality? TIA
Old 31-08-2011, 6:20 PM   #100
Whats in the offer this time round, just the receiver of what?, & yes any FTA receiver portable or other wise will be fine.
lotsatoys (31-08-2011)
Old 31-08-2011, 8:52 PM   #101
Complete kit with dish,lnb,cable and reciever Tevion branded 3yr gtee,seems quite a good deal to me.
Old 31-08-2011, 10:55 PM   #102
is this "F1 coverage" free?
Old 01-09-2011, 7:09 AM   #103
It is,according to the very first post on this thread. Hence the question as to its suitability for receiving rtl F1.
Old 01-09-2011, 4:22 PM   #104
Just had another thought,could an old (about 10yrs old) Sony sky box be used for this purpose? I doubt it,but thought it would be worth asking here,before nipping down to my local Aldi.
Old 01-09-2011, 4:40 PM   #105
That would be analogue, not digital.
Old 01-09-2011, 5:10 PM   #106
Thanks: Gave 16, Got 158
Would it? There were at least two Sky Digital Sony boxes.
Old 01-09-2011, 5:12 PM   #107
If you mean receive RTL etc, then it may or may not work as Sky further crippled the firmware a few years ago.
Old 01-09-2011, 7:41 PM   #108
Ten years ago? Time flies.
Old 01-09-2011, 8:10 PM   #109
Thanks: Gave 4, Got 157
That I don't recall at all!
Old 01-09-2011, 8:35 PM   #110
Thanks: Gave 27, Got 100
there was an add channel option that allowed you to manually enter frequencies as long as the symbol rate was 22000 or 27500. It was popualr when ITVHD first started as it wasnt visible on the SKY EPG for while but could be added manually.
Old 01-09-2011, 10:40 PM   #111
I think you mean when ITV sd was first available on the Sky platform. I did indeed use the add channels option to receive ITV before it was officially available.
Sony did indeed manufacture two boxes one numbered 750 and a slightly upgraded model a year or so later numbered 760.
I have both boxed in the loft. Both were fairly unique at the time as they had optical digital outputs that provided pcm stereo.
All I need to know if one of these could be used to receive RTL,but I guess the only way to find out is to try it,by which time Aldi will have sold the last six kits they have in stock
Old 01-09-2011, 10:57 PM   #112
Thanks: Gave 83, Got 425
It should work fine, the firmware crippling is a rather recent development in the life of Sky Digital. When you do try it don't point it to 28.2E and don't let it update firmware just in case.
lotsatoys (02-09-2011)
Old 01-09-2011, 10:59 PM   #113
Didn't Sky Digital launch in 1998?
Old 01-09-2011, 11:13 PM   #114
Thanks: Gave 21, Got 4
You can watch Formula One on TF1 in HD for free with TNTSat HD... no idea about English audio though as I haven't been able to watch French TV for sometime and won't be able to for a while more but they have English audio every now and again for English language shows so there maybe English for the races
Old 01-09-2011, 11:23 PM   #115
pedro2000uk's Avatar
Thanks: Gave 174, Got 539
TF1 is one we've got listed as a possible for F1
Old 02-09-2011, 12:08 AM   #116
Quite probably - time flies fast then.
Old 02-09-2011, 11:40 AM   #117
how long is a tntcard active for? there site says for 4 years but is it on a fixed cycle so for example all cards expire in 2012 or is it 4 years from the moment the card is inserted?
Old 05-09-2011, 3:04 PM   #118
thestig230's Avatar
Thanks: Gave 46, Got 45
Can someone confirm if this kit Ross HD+ Satellite Kit, 5015056512297 would allow me to watch the F1 in HD next year for free?
EDIT - I realise I will have to lock onto Astra 1 at 19.2 East to get RTL? Which will have German commentary?
Old 05-09-2011, 3:12 PM   #119
No, you would need a receiver that reads the HD+ cards, they can be had for around £100 with the card included.
Old 05-09-2011, 3:18 PM   #120
thestig230's Avatar
Why is that?
Any links?
