Hello to everyone.
Just tossing in my two cents here about the DM800HDse. I just purchased it around Christmas since my 3 year and 6 month old DM800 just died with a power surge. Sadly, it was at the wrong place at the wrong time(from the living room to the bedroom), and it didn´t have a surge protector like the rest of the av family components here at home.
It made me wonder what to buy next. Since it worked almost every day(with an internal hard drive), I had a fan installed, and choosing the right image firmware, it came to be stable and less prone to heat buildup. So I must say that, it did what it was supposed to do and a little bit more. I also own a Humax HDCI-2000 which is a major toaster, and has had it's PSU replaced. Trouble is that I still have a Nokia 9800s which is from the year 2000 still working flawlessly in my den receiving the BBC and ITV channels with amazing picture quality that not even the new receivers come close to it! Yes the channel changing is very slow, menus are a pain to change, but, it still works.
There may be more options out there, but Dream Multimedia has been around for some time. Nokia pulled out of the STB biz early in the decade, Humax is still around, but not very competitive. I also owned a Neotion 601 which was to be "the future" with it's mpeg-4 tuner option, but also pulled out. I was tempted to buy the Vu +Duo(no doubt about the quality, my friend owns one and I love it), but since I am used to the Dreambox, and saw that Dream came out with this second edition, I opted to continue with Dream. I am thinking of buying a Vu +Duo for the den. My friend is going to lend me his unit, and that way I can compare both units side-by-side. It will be good to do this, because I am tempted to see the results with my setup here at home. Since the DM800se is small in size, it might end up in the den and leave the Vu +Duo in the living room.
I am though, satisfied with the DM800se for now. Compared to the DM800, quicker zapping, much cooler working temperatures(average 33ºC compared to the DM800 which had an average temp. of 50ºC) , and very stable. Less proning to crashes(depending on which image you upload). HD channies are great but also depending on which image you upload and fine tune. It is a pain to fine tune the image quality in the menu option in of some fw images, but once you get it right, they look great. SD channel are average but that might just be me. The tuner is a little less sensitive(the DM800 had an Alps tuner), but still o.k. for what it does. Let's see when I try out the Vu +Duo.
