Originally Posted by slim75 Thanks Pedro.
Not sure about the Satellites at all, but do know the Missus wouldn't let me have a dish any bigger than 1m
Just want to know exactly what i'd need (including a good receiver preferably able to receive HD signals) and also would like a point in the right direction to good suppliers/installers like your self  |
You can choose a dish size from a Sky dish to 1m. You can still get a lot of channels on a Sky dish on a motor (5000+ plus all the Freesat channels and over 30 satellites from all over the place - some carry US UK movies/ comedy/ soaps / programs etc.. around the arc... usually subtitled.. but some of the best need a minimum of a good quality 85cm or 90 to get Arabsat and the popular US English
free movies in Macclesfield and a sensitive receiver & LNB plus a really good installation - anything less and you either won't get them or they will break up & dissapear in any bad weather.
Dish makes we will use are Raven Sky dishes z1 or z2 / Triax / Orbital / Gibertini and some others we'll modify first to get them up to standard if someone has bought them already. Black Ultra LNBs / Technomate receivers mostly and various Linux receivers (& their images)/ Webro cable & strong brackets we make.
Not sure about history channel- yesterday that was called History is on Freeview(aerial) and Kuwait 2 seems to be the documentary channel now on Arabsat. There was a HD History channel free on 15w I think and various other channels that feature docu's now and again.. and there are the Freesat channels like CBS Reality etc.. as any motorised will motor to them too.
Football is all over the Forums atm with the various providers as stated above... we don't get involved in Card Share, programming or patching etc.. we just do the engineering install wise whether it's a linux box or TM and it's up to individuals etc.. what they do after..
Plenty about the receiver you mentioned in you 1st post around...
One thing we come across a lot is that Linux receivers aren't usually as good at controlling motors- blind scanning or sensitivity as Technomates are (the 3/5 & 6000 series) so they do what they do best but you can lose functionality in those areas so you can set a motorised system up and a TM gets 7w Nilesat (1-1.1+ needed in Macc btw) and good 26e, 16e etc.. and then switch over to the Linux receiver and it can't find 7w and 26e etc.. is a lot lower.
My advice for anyone is, if you can, is put any recent Technomate together with a Linux box - looped through and use the TM to do what it is good at (as above- motor control/ blind scan & sensitivity) and the Linux box for what it is good at ...
(unless the linux receiver & image is OK for those).
