DreamBox Dm800 & Dm8000 Owners Thread Pt1
Old 03-08-2010, 7:01 PM   #151
Thanks: Gave 44, Got 8
Originally Posted by killz187 View Post
Sorry but how do i go about it on Dreamedit ?I have looked but can not see anything that says Satellite edit name something like that.
load your channel list.go to right hand side,right click on hot bird then it should say rename bouquet right click and rename. then close dreamedit and it will ask if you want to save changes yes of course.
Old 03-08-2010, 9:21 PM   #152
killz187's Avatar
Thanks: Gave 104, Got 50
Sorry if i explained it wrong i want to rename Satellites in green button not the Bouquets.
If you go on the dreambox Channel seletion you have Satellittes,Provider,Favourites,All.The ones i want to edit are the Satellites .
Old 06-08-2010, 8:46 PM   #153
Thanks: Gave 6, Got 13
i got dm8000 with dark hole image quick question not sure if my box is faulty or its a bad image. When i pause a channel and switch channel the pause doesnt stick and no recording is done.
Old 06-08-2010, 8:55 PM   #154
thfccambs's Avatar
Thanks: Gave 803, Got 1,666
Lost me here a bit, you saying you pause say BBC the change channel and watch another, then go back to BBc and it's no longer paused?
Where's recording come into it?
Didn't even know this would be possible.
I use DreamElite on my DM8000, works great, pause and record isn't a problem at all
Old 06-08-2010, 9:26 PM   #155
killz187's Avatar
Does anyone know if this is possible Edit the name of my Satellites eg Hot bird (13.0E) i want to change it to
Hot bird 6/8/9 (13.0E)
Old 06-08-2010, 9:39 PM   #156
Thanks: Gave 4, Got 3
you will have to alter the name in the satellites.xml file located in var/tuxbox (open with an xml editor is best e.g. crimson editor etc)
e.g.
<transponder frequency="12739000" symbol_rate="4167000" polarization="1" fec_inner="4" system="0" modulation="1"/>
<transponder frequency="12740000" symbol_rate="5632000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="12744000" symbol_rate="4167000" polarization="1" fec_inner="4" system="0" modulation="1"/>
</sat>
<sat name="Hot Bird 6/8/9 (13.0E)" flags="0" position="130">
<transponder frequency="10719000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="10723000" symbol_rate="29900000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="10758000" symbol_rate="27500000" polarization="1" fec_inner="4" system="0" modulation="1"/>
<transponder frequency="10775000" symbol_rate="28000000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="10796000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="10815000" symbol_rate="27500000" polarization="0" fec_inner="4" system="0" modulation="1"/>
<transponder frequency="10834000" symbol_rate="27500000" polarization="1" fec_inner="3" system="1" modulation="2"/>
<transponder frequency="10853000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="10873000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="10892000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="10911000" symbol_rate="27500000" polarization="1" fec_inner="3" system="1" modulation="2"/>
<transponder frequency="10930000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="10949000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="10971000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="10992000" symbol_rate="27500000" polarization="1" fec_inner="2" system="0" modulation="1"/>
<transponder frequency="11013000" symbol_rate="27500000" polarization="0" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="11034000" symbol_rate="27500000" polarization="1" fec_inner="3" system="0" modulation="1"/>
<transponder frequency="11054000" symbol_rate="27500000" polarization="0"
you will have to alter the words i have underlined inside the quotation marks
killz187 (06-08-2010)
Old 06-08-2010, 10:02 PM   #157
killz187's Avatar
Thanks for the help shirehorse99 will do that this weekend ans start enjoying the footie from next week.
Old 06-08-2010, 10:14 PM   #158
thfccambs's Avatar
Why?
Your getting a little like i used to be, obsessed at gettting everything set just perfect. Trust me it will never happen.
Old 06-08-2010, 10:34 PM   #159
Yes thats what i mean no recording, just pausing. I dont understand why this is not possible. If you pause something it should start recording and i should be able to go back to it.
Old 06-08-2010, 10:50 PM   #160
thfccambs's Avatar
Seriously confused me, if you press pause it will pause, if you press red
square bottom right on remote it will record. Does atleast on my DM.
Old 06-08-2010, 10:57 PM   #161
killz187's Avatar
Why?
Since i have had this box i have never had a full day of watching a film or something.I have to do something to the box,anyway i hope this is the last weekend of messing with it looking forward to the footie.Only thing left is setting my Bouquet for all sports channels.
Old 06-08-2010, 11:47 PM   #162
thfccambs's Avatar
What box do you have again? Enigma 2 box?
I have a channel list if you want it?
Old 07-08-2010, 12:15 AM   #163
killz187's Avatar
Yes please send us a a list whenever you have timeIs this an up to date list?I have one of yours you sent on another thread a few months back.
Old 07-08-2010, 10:27 AM   #164
thfccambs's Avatar
More upto date and more for HD users.
Got a friend working on another more upto date at the moment, will also post that one when he's done mate.
killz187 (07-08-2010), rcaudwell (09-08-2010)
Old 08-08-2010, 9:25 PM   #165
sky uk
originally created by B16MCC
i have just added additional channels that were moved and added.
c5hd and b4u movies moved.
Old 08-08-2010, 10:15 PM   #166
Oily's Avatar
Thanks: Gave 63, Got 87
Do you mean 'timeshift' ? There's a plugin called 'permanent timeshift' that you can use.You need somewhere to record to mind
Old 10-08-2010, 1:29 AM   #167
Never had a sat before, been in IT for around 8 years so hopefully i'll manage something, so i'm after best practice guide to working and understanding the DM800 box and the whole satellite tv stuff (the idiots guide..., Basics, FAQ)
The guy is coming to set it all up Friday.. the package does not come with and HardDisk, can I buy a normal SATA disk or does it have to be special from dreambox as it seems to be used by most of the users to record?
Also does the OS run on some small memory and when you make changes with dreamedit - what files are these and on which disk are they stored..
Is it worth going for the 8000 instead, might have to wait longer and cost me double??
Sorry about all the level 100 questions...
Thanks in advance.
Old 10-08-2010, 1:14 PM   #168
Stanman's Avatar
Thanks: Gave 35, Got 47
I know this is a DM thread but for Jwirth - have you considered th Vu+, I find it does everything I need and has dual tuner as well.
Old 16-08-2010, 11:42 PM   #169
yeh go for the duo mate
Old 20-08-2010, 9:09 AM   #170
thfccambs's Avatar
Sky Sports News Hd has started testing on Astra 28.2 East
12265H 29500 3/4
SID 3849 512/660/512
SID 3859 512/640/512
Old 21-08-2010, 1:54 PM   #171
Conspicuous Member
Gliese 581c's Avatar
Thanks: Gave 696, Got 454
12265H 29500 3/4
Scanned those settings, picked up nothing.
Old 21-08-2010, 3:37 PM   #172
killz187's Avatar
I did scan mine and i picked 2 of them.Did you do a manual scan ?If so did you change your settings in service scan to Dvs-s2?
Old 21-08-2010, 5:08 PM   #173
Conspicuous Member
got it now, when I scanned s2 it jusmped from 3/4 to 9/10. Put back to 3/4 and found it ok. Nothing showing yet though, just countdown timer.
Old 22-08-2010, 1:39 PM   #174
thfccambs's Avatar
Newcastle v Villa FTA in HD
10°east
11305 vertical
30000
5/6
DVB-s2
Old 22-08-2010, 4:57 PM   #175
Davey H's Avatar
Thanks: Gave 28, Got 154
10°east
11305 vertical
30000
5/6
DVB-s2
Fulham v Man Utd FTA on the same tp
Old 23-08-2010, 8:21 PM   #176
thfccambs's Avatar
Man City v Liverpool
Game is on live in HD with English Comm.
FTA
10 east
Frequency: 11305 - Pol: V - SR: 30000 1/2
PLTV
Davey H (23-08-2010), pedro2000uk (28-08-2010)
Old 26-08-2010, 2:51 PM   #177
killz187's Avatar
On the Dm 800 you have LNB in and LNB out,If i connect a cable to LNB out and run it to my bedroom and get another Sat box will that work?I dont mind if one box will be in standby.I will be using a motorised dish.The main thing i want to avoid is running another cable from the dish.
Old 26-08-2010, 10:11 PM   #178
it will work but only one box will work at any given time.
killz187 (26-08-2010)
Old 26-08-2010, 10:24 PM   #179
killz187's Avatar
Will my second box be able to operate my motorised dish when the other box is off?
Old 31-08-2010, 4:33 PM   #180
Thanks: Gave 5, Got 17
To load up Satmate uk using nabilosat blackhole E2
Press Blue button twice
Go to Black Hole Epg Panel
Choose Satmate-sky uk and add it.
Then download your epg,done
Crikey, thanks for the info. I can't believe it was as easy as that.
I've put up with blank listings and "now and next" on only those channels recently visited, ever since buying the DM800 several months ago!
