Dish installation- Manchester?
Old 06-03-2010, 7:56 PM   #1
1,156, Level: 7
Points: 1,156, Level: 7 Points: 1,156, Level: 7 Points: 1,156, Level: 7
Hello all,
Can anyone recommend a satallite dish engineer in the Manchester Area.
I've just aquired a Darkbox 2008 hd combo and I'm hoping to install a 80cm motorised dish. I want to be able to connect to multiple satallites. What are the communities recommendations as to which satallites are the most worthwhile.
Old 06-03-2010, 8:28 PM   #2
1,713, Level: 9
Points: 1,713, Level: 9 Points: 1,713, Level: 9 Points: 1,713, Level: 9
Thanks: Gave 1, Got 1
Had mine installed(today) by Albsat,Blackley , near heaton park.
They got recommended to me.
Have to say they were superb.
With a motorised dish you will be able to pick up the main sats (Thor, Hotbird, Astra 19 etc)
Old 06-03-2010, 8:37 PM   #3
1,156, Level: 7
Dish installation
Thanks for your reply talon_s.
What kind of installation did you have, regular sky?
Just wondered how much it cost?
Old 06-03-2010, 8:43 PM   #4
pedro2000uk's Avatar
5,970, Level: 18
Points: 5,970, Level: 18 Points: 5,970, Level: 18 Points: 5,970, Level: 18
Activity: 42.2%
Activity: 42.2% Activity: 42.2% Activity: 42.2%
Thanks: Gave 70, Got 324
We install in Manchester/ (& Cheshire/ N Staffs/ N Derbyshire), for smaller installs (big dishes & we go further)..... PM me with details etc.
As for satellites .. free TV in Manchester should always include Arabsat - BADR4 at 26e (free movies etc) - you need a little bit bigger than an 80 though & a good dish/ lnb - the receivers definitely OK though....
We usually like to get about 30+ satellites 45e to 45w or further unless it is a very restricted line of sight... usually get 30+... then it's all about numbers- weak signals/ weak beams.. & a solid job... the difference between a really good install & er not.
Old 06-03-2010, 8:44 PM   #5
1,713, Level: 9
Had my dish replaced,new motor and LNB + setup = £160.
They charged about £60 to install.
Total = £160 for equipment and installation
Got Sky on a separate fixed dish and a motorised dish for hotbird, thor etc
Old 06-03-2010, 9:18 PM   #6
5,970, Level: 18
Activity: 42.2%
What dish/motor is that for talon.. and what sats do you get.
Old 06-03-2010, 9:49 PM   #7
1,713, Level: 9
Alsat superior dark motor, not sure dish make, they did say the make but can't remember it.
Using it with a dreambox 7000. Just programmed thor, astra and hotbird on it for now.
Old 06-03-2010, 10:33 PM   #8
5,970, Level: 18
Activity: 42.2%
Good motor choice... & stb..
Old 07-03-2010, 7:33 AM   #9
6,595, Level: 19
Points: 6,595, Level: 19 Points: 6,595, Level: 19 Points: 6,595, Level: 19
Thanks: Gave 12, Got 95
I have got someone in manchester if you still need someone
Old 11-03-2010, 9:23 AM   #10
5,715, Level: 17
Points: 5,715, Level: 17 Points: 5,715, Level: 17 Points: 5,715, Level: 17
Thanks: Gave 70, Got 10
Sent you a PM
Old 12-03-2010, 12:06 PM   #11
5,970, Level: 18
Activity: 42.2%
Got message have sent you a pm..
