Multiroom, HDTV
Old 08-11-2009, 4:15 PM   #1
888, Level: 6
Points: 888, Level: 6 Points: 888, Level: 6 Points: 888, Level: 6
Multiroom, HDTV
Hi there
Can anyone cofirm and add to what I think I know. I want to have mutiroom HDTV and have installed HDMI 1.3b to 4 separate locations in the house. I understand the video and audio signal from a HDTV tuner (locked away in a server room is carried down the HDMI cable, and is fed into either the display (or a reciever which directs video to display and sound to surround speakers). Am i right?
Victor
Old 08-11-2009, 7:44 PM   #2
888, Level: 6
Re: Multiroom, HDTV
Of course through a video matrix....
Old 08-11-2009, 8:04 PM   #3
2,332, Level: 11
Points: 2,332, Level: 11 Points: 2,332, Level: 11 Points: 2,332, Level: 11
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 0, Got 38
Re: Multiroom, HDTV
sounds about right
Old 09-11-2009, 7:32 PM   #4
888, Level: 6
Re: Multiroom, HDTV
thnx
my worry was whether tv tuners carry the audio and video signal down one hdmi cable to the receiver...
Old 10-11-2009, 9:24 AM   #5
961 961 is offline
6,648, Level: 19
Points: 6,648, Level: 19 Points: 6,648, Level: 19 Points: 6,648, Level: 19
Activity: 9.1%
Activity: 9.1% Activity: 9.1% Activity: 9.1%
Thanks: Gave 145, Got 406
Re: Multiroom, HDTV
Originally Posted by vjohns View Post
thnx
You need to see the spec for the box concerned
For example I believe sky hd boxes only carry stereo audio through the hdmi cable and that a separate cable (Toslink or similar) is required for 5.1 audio
Old 10-11-2009, 10:16 AM   #6
888, Level: 6
Re: Multiroom, HDTV
thnx
I am looking at the humax foxsat pvr. as far as i gather even surround audio formats are piped through hdmi.
Old 10-11-2009, 11:54 AM   #7
28,189, Level: 40
Points: 28,189, Level: 40 Points: 28,189, Level: 40 Points: 28,189, Level: 40
Activity: 95.3%
Activity: 95.3% Activity: 95.3% Activity: 95.3%
Thanks: Gave 39, Got 2,263
Re: Multiroom, HDTV
thnx
Dolby Digital 5.1 or 2.0 (for HD channels) is carried on the hdmi output of a Foxsat-hdr. It's not on a Sky HD box though.
Old 11-11-2009, 8:14 AM   #8
888, Level: 6
Re: Multiroom, HDTV
thnx. one other point. is it possible to control the humax foxsat HR remotely from each room in the house if it is locked away in a server room (I am thinking of having logitech universal remotes in each room)? I have already installed cat 6 and 7 cabling to each room (from the server room) so one can be used for IR control. I am also considering wireless remote control but have yet to look into it - any thoughts?
Old 11-11-2009, 8:32 AM   #9
888, Level: 6
Re: Multiroom, HDTV
graham
can you pls clarify. i will be having two pvr tuners in the server room - the foxsat and an-other. will i need anything between the 4 lnbs i will have and the tuners - an amplifier of any type fpr example? the cable run fron the dish to server room is about 20 metres. forgive my ignorance.
