Tm 6900
Old 26-10-2009, 9:14 PM   #1
1,392, Level: 8
Points: 1,392, Level: 8 Points: 1,392, Level: 8 Points: 1,392, Level: 8
Thanks: Gave 5, Got 0
Exclamation Tm 6900
Hi Folks, first post on this forum so here's hoping!
Anyway looking to buy a Technomate TM 6900 (unless anyone can suggest better for the same budget) requirements are twin tuner, PVR facility and of course HD, Freeview is a bonus.
Couple of things I would like to know before taking the plunge:
Twin tuners - do they need two seperate feeds?
would I be able to use a twin LNB (for 19 and 13 degres) and if so would it be one feed to each tuner or what?
Is the PVR like a BT vision box i.e. can record two programmes at a time or watch one record another?
if possible can a Blue Ray player be hooked up and the output then recorded?
Sorry if any of this sounds dumb, and thank you in advance
Graham
Old 27-10-2009, 12:25 AM   #2
7,032, Level: 19
Points: 7,032, Level: 19 Points: 7,032, Level: 19 Points: 7,032, Level: 19
Thanks: Gave 82, Got 315
Re: Tm 6900
Know next to nothing about this - but I think you've misread the spec. It has two tuners but one is satellite & one terrestrial digital, & I doubt very much if they can operate at the same time. So you won't be able to watch one channel while recording another; though you'll probably be able to record one while playing back a recording. Nor, would I have thought you can use it to record from an outside source such as a Blu-ray player.
Not sure I fully understand your question about connecting LNBs for different satellites, but as there's only one satellite tuner you'll be limited to one connection at a time.
graaaham` (27-10-2009)
Old 27-10-2009, 10:16 AM   #3
28,180, Level: 40
Points: 28,180, Level: 40 Points: 28,180, Level: 40 Points: 28,180, Level: 40
Activity: 99.4%
Activity: 99.4% Activity: 99.4% Activity: 99.4%
Thanks: Gave 39, Got 2,262
Re: Tm 6900
Hi Geoffbob you are correct the 6900 can only record 1 channel at a time and can replay an existing recording while recording, but it can use multiple lnb's or a motorised dish as the sat tuner supports diseqc switching.
There's a link to a review here
Technomate UK - Your digital partner for life
Geofbob (27-10-2009), graaaham` (27-10-2009)
Old 27-10-2009, 1:01 PM   #4
7,032, Level: 19
Re: Tm 6900
Thanks Graham - though personally I prefer to stick to old fangled PVRs with a built in HDD & less technical jargon in the spec!
However, the OP, quadruple-A Graaaham, may be very interested in the TM-7100. which the Technomate Newsletter says is being launched on 1 November - that does have twin satellite HD tuners, so should do everything he wants - though at what price, one wonders.
Old 27-10-2009, 1:43 PM   #5
28,180, Level: 40
Activity: 99.4%
Re: Tm 6900
Couldn't agree more, thats why I use a Foxsat-hdr and as to the price twin tuner generic fta boxes in my experience come in the £400.00 plus price bracket
