Originally Posted by fishcakes Ok, my minds pretty well made up then, just one last thing as I'm still not sure. For the time being until i get a new lnb and cable, if i get the foxsat and use the current sky cable plugged into one socket on the foxsat (no other coaxial cables etc), will i be able to record on one channel and watch another?
cheers for your help man  |
Yes provided you connect the short tuner loop on the back - tuner 1 out tuner 2 in with a short piece of coax and 2 f connectors.
Download this webpage and open it with your browser
4shared.com - online file sharing and storage - download FoxsatStaticMK2_011.htm
Look at column 4 marked block. You can record any two channels in the same block. What you can also watch depends on which channels you record together. Look at the colours in cols 1-3.
If the colours of the two channels are recording are in the same colour you can watch any other channel in the same block. If they are different then you can watch any channel in the same colour as either recording.
Note
1 The table includes all the ITV 1 regions depending on the post code used in reallity you only get two ITV 1 regions your own at 103 and London ITV 1 at 977. A London postcode only gets the one at 103 and 977.
2 If one of the channels you are recording has regional variations you can change what 3rd channel viewing is available by switching regions.
Don't forget when you upgrade to two cables you need to do a factory reset to tell the hdr you now have 2 cables
