satellite box
Old 17-10-2009, 7:06 PM   #1
3,066, Level: 13
Points: 3,066, Level: 13 Points: 3,066, Level: 13 Points: 3,066, Level: 13
Question satellite box
Help needed ,
my TV pic not the best, would a freeview box or sky box get ok pic.?
forgot to mention its for my caravan in the middle of nowhere.
just want to get the best pic with most channels poss.
cheers
Old 17-10-2009, 7:43 PM   #2
2,332, Level: 11
Points: 2,332, Level: 11 Points: 2,332, Level: 11 Points: 2,332, Level: 11
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 0, Got 38
Re: satellite box
either would be okay, freeview (as long as its in an area that can get it), freesat, or sky via subscription.
Old 18-10-2009, 4:26 PM   #3
1,237, Level: 7
Points: 1,237, Level: 7 Points: 1,237, Level: 7 Points: 1,237, Level: 7
Thanks: Gave 20, Got 8
Re: satellite box
If you have a poor picture through a TV aerial then the liklihood is that you won't be able to pick up all freeview channels.
If you fix a small dish to the caravan you'll be able to pickup Sky and Freesat. Both good options.
Old 19-10-2009, 4:38 PM   #4
6,595, Level: 19
Points: 6,595, Level: 19 Points: 6,595, Level: 19 Points: 6,595, Level: 19
Thanks: Gave 12, Got 95
Re: satellite box
Yep id go for freesat all day long as long as you have a line of site the picture is always guaranteed where as an aerial your restricted to the area you are in.
