AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Satellite Navigation (Sat Nav)
Closed Thread
LinkBack Thread Tools Display Modes
Old 16-03-2008, 10:32 PM   #1 (permalink)
Thanks: Gave 29, Got 247
Change your original Navigo menu
I'm not sure I should tell you how to change your Navigo menu
What do the Mods think?
pjclark1 is offline
Old 16-03-2008, 11:27 PM   #2 (permalink)
Thanks: Gave 38, Got 178
Re: Change your original Navigo menu
No Garmin Mobile XT?
Erm...Yeah, I built a Mac
DVD 2 WMV Guide
meansizzler is offline
Old 17-03-2008, 12:07 AM   #3 (permalink)
I'm getting the hang of this now
pjclark1 is offline
Old 17-03-2008, 10:30 AM   #4 (permalink)
Thanks: Gave 20, Got 63
Nothing illegal in changing the menu of the software that came with a device you own. Go on, be a devil... I had a dig through yfloader when I was trying to get at a way of just kicking off the 'System' screen but I couldn't see an entry point, nor as it happens any icons in the resources. If you've dug further, share!
alpine101 is offline
Old 17-03-2008, 3:07 PM   #5 (permalink)
I know, let's goad pjclark so he tells us.
I don't believe you've done it pj, you've just photoshopped an image.
Old 17-03-2008, 4:16 PM   #6 (permalink)
To change the Original Navigo Menu
You need to type in "Residentflash2" into your Navigo file browser as it is a hidden directory. You might want to copy the entire "Yfap20" directory to your SDMMC card and make changes from there. Then run the Shell.exe from that folder (no chance of bricking it then)
1) Copy \Residentflash2\YFAP20\SKINS\YFGB_BLUE_BT\Shell.xm l to your PC ( I used total command to copy to SDMMC then to PC)
2) Use Notepad to edit the paths to point to any programmes you want to use
3) I changed (first occurrence only)
"MP3.EXE" to "SDMMC\Program Files\CorePlayer\player.exe"
"MP4.EXE" to "SDMMC\Program Files\CorePlayer\player.exe"
"\SDMMC\MobileNavigator\MobileNavigator.exe" to "\SDMMC\Program Files\MioMap33\miomap.exe"
4) Copy the altered SHELL.xml back to \Residentflash2\YFAP20\SKINS\YFGB_BLUE_BT\Shell.xm l
5) Run YFLoader.exe as usual and it will run all your own apps using the Original Navigo menu system
You can now run multiple apps of your own choosing from the original Navigo menu .... including several different satnav programmes.
The menu layout is defined from within the Shell.xml file in the skin subdirectory
The text for the menu is defined within the Language subdirectory English.xml
The Button icons ad graphics are defined from within the .dat file in each skin subdirectory
Example, how to add a close button to the front menu
Replace the existing "power" section with this
<SECTION CLASS="YFButton" NAME="Close" ID="1000">
<RECT>285,0,320,35</RECT>
<PID>132,133,0,0</PID>
<STYLE>WS_VISIBLE,BS_PUSHBUTTON,BS_TRANSPARENTIMAG E</STYLE>
</SECTION>
<SECTION NAME="power" CLASS="CYFPower" ID="1100">
<RECT>245,0,280,35</RECT>
<PID>116,115,114,113,112,118</PID>
<LEVEL>0,20,35,55,80,100</LEVEL>
<SHOWMODE>STATIC</SHOWMODE>
<STYLE>WS_VISIBLE,BS_CENTER,BS_VCENTER</STYLE>
</SECTION>
Each button has it's own definition between <SECTION NAME ........ and </SECTION>
PID defines the Icon (35 x 35 for small icon, 90 x 90 for large icon)
RECT defines the position on the page x1,y1,x2,y2
Download a trial version of "PE Explorer"
Copy the .DAT file to your PC and drop it into PE Explorer and press the diamond, and view all the icons and graphics, if you're clever you can edit them to whatever you want.
Here is a shot after an icon or two has been edited and reinserted in the .DAT file
pjclark1 is offline
alpine101 (17-03-2008)
Old 17-03-2008, 7:32 PM   #7 (permalink)
Excellent work PJ, that's why I couldn't find any icons inside yfloaders resources...
Old 17-03-2008, 8:19 PM   #8 (permalink)
Originally Posted by pjclark1 View Post
Some of the buttons need a touchup, but it all works well
Wot! No animated icons?
Old 17-03-2008, 10:05 PM   #9 (permalink)
Here is the button and language base pack v1.02 (Custom buttons at 800+, you need this for all skins)
(Button shading fixed for memorymap and coreplayer icons on bottom row, shadows tarted up)
http://rapidshare.com/files/10068594...oBase.rar.html
Here is the 6 button/4 button/6 button skin
http://rapidshare.com/files/10041556...utton.rar.html
Here is a 6 button/6 button/6 button skin (menu 2 works exactly as the original menu)
http://rapidshare.com/files/10041580...utton.rar.html
(Use at your own risk)
pjclark1 is offline
freecell (19-03-2008), Weigh-Man (19-03-2008)
Old 18-03-2008, 9:11 PM   #10 (permalink)
Thanks: Gave 3, Got 0
Just wanted to say a big thanks
I used your base files to design my own menu's and now have TomTom 6, MioMap 3.3 and Turbodog 5 all running from one SD card and all through the Navigo menu.
Nice work.
Weigh-Man is offline
Old 19-03-2008, 10:02 AM   #11 (permalink)
Thanks: Gave 1, Got 1
post removed by request
Last edited by porky; 19-03-2008 at 12:13 PM. Reason: someone called me a name and i feel bad now
porky is offline
Old 19-03-2008, 10:30 AM   #12 (permalink)
Thanks: Gave 0, Got 7
pjclark: hmmm - i've seen these posts before somewhere!
fr0d0 is offline
Old 19-03-2008, 11:18 AM   #13 (permalink)
I think pjclark is..... sarah99 or vice versa!
kar999 is offline
Old 19-03-2008, 12:14 PM   #14 (permalink)
my apologies for posting in the wrong thread, post edited.
porky is offline
Old 19-03-2008, 6:34 PM   #15 (permalink)
Re: Navigo Volume Control with MioMap
I am not sure if this is posted elsewhere but thought I would share it.
I run MioMap 3.3 through an un-hacked Navigo but the volume control on the Navigo wouldn't work properly, after some fiddling I got it working.
Insert your SD card into your PC, go to the MioMap Folder and look for Data.Zip, open it using Winzip/Winrar, open the folder called Config and then open Keybind.txt with notepad.
Now change the default settings to what is shown below.
[default]
C1="TILTDOWN"
C2="TILTUP"
C3="SWITCH_ROUTEINFO_ITINER"
C4="SWITCH_MAP_COCKPIT"
C5="PUTPINTOGPS"
C6="SETTINGS"
C7="VOLUMEUP"
C8="VOLUMEDOWN"
C9="TOGGLEMUTE"
UP="ZOOMIN"
DOWN="ZOOMOUT"
LEFT="ROTATELEFT"
RIGHT="ROTATERIGHT"
DIAL="MINIMIZE"
END="MINIMIZE"
JOGUP="GOTOHOME"
JOGDOWN="MAINMENU"
ENTER="FOLLOW_OR_ANNOUNCE"
Save the file, making sure it goes back in the Data.Zip folder
Job Done, the Navigo volume control will adjust the volume in MioMap
UPDATE: This also works for Miomap 3.2 and iGO 8 - same method as above
change, menu, navigo, original
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Campaign for Change in Sky Menu Music zarguio Sky HD 45 17-10-2007 9:14 PM
Campaign for Change in Sky Menu Music zarguio Sky and Sky+ 2 02-10-2007 8:40 AM
Campaign for Change of Sky Menu Music zarguio Sky and Sky+ 1 01-10-2007 9:54 PM
Change Menu Screen luckylewis DVD Recorders, Recording and Media 4 06-04-2007 2:42 PM
Menu Colour Change BioHzrd Virgin Media 8 10-02-2007 6:20 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
