AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Satellite Navigation (Sat Nav)
LinkBack Thread Tools Display Modes
Old 10-03-2008, 2:34 PM   #1 (permalink)
Thanks: Gave 18, Got 5
SD or SDHC with ebuyer navigo satnav
Im looking for a 4gb sd card that i can use on my navigo. Not sure if im going to hack it or just run the tomtom and miomap directly from the sd card yet, but which is it i need to get for compatability with the navigo. I asked this before and had it a brilliant explanation given but cant remember the answer and the thread ebuyer nabigo thread was chopped.
So thanks in advance
atsoc15 is offline
Old 10-03-2008, 3:20 PM   #2 (permalink)
Thanks: Gave 0, Got 6
Re: SD or SDHC with ebuyer navigo satnav
I said max 4GB SD card formatted as FAT (FAT16).
Someone else said SDHC works fine (FAT32).
siteguru is offline
Old 10-03-2008, 4:36 PM   #3 (permalink)
Thanks: Gave 29, Got 247
I'm using a 4GB Sandisk microSDHC card in mine (FAT32) and it works a treat.
£12 on Amazon from Findmemory (aka dvd.co.uk) with a SD adapter and a SDHC USB card reader.
I always buy microSD with adapters as they are a higher speed spec than normal SD cards.
pjclark1 is offline
Old 11-03-2008, 12:13 AM   #4 (permalink)
Thanks: Gave 2, Got 30
Tha older 4gb Transcend SD Card works fine also.
JT37" One Exellent LCD By Hannspree with (CPT) panel.
Gedd is offline
Old 12-03-2008, 9:42 AM   #5 (permalink)
4gb sd card £8.99 delivered at play.com:
http://www.play.com/Electronics/Elec...tml?P36=7PVFUX
should work with the navigo satnav
don2345 is offline
Old 14-03-2008, 11:53 AM   #6 (permalink)
I use this, plenty of storage for £20
Veho 8GB Class 6 150x Hi Speed Secure Digital Card
scoutfu is offline
ebuyer, navigo, satnav, sdhc
Refbacks are On
Thread Thread Starter Forum Replies Last Post
eBuyer NaviGo GPS mains charger. kazam401 Satellite Navigation (Sat Nav) 12 21-05-2008 4:19 PM
What happened to the Ebuyer Navigo Thread? siteguru Satellite Navigation (Sat Nav) 5 12-03-2008 11:03 PM
Navigo Sat Nav (ebuyer) Stevebarton2 Satellite Navigation (Sat Nav) 4 19-02-2008 6:07 PM
For Trade : 6GB micro SDHC for 4GB micro SDHC jasper_mccrea Archive : Completed Business and Expired Threads 11 22-10-2007 9:24 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
