AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Satellite Navigation (Sat Nav)
LinkBack Thread Tools Display Modes
Old 03-03-2008, 12:12 PM   #1 (permalink)
Thanks: Gave 1, Got 0
TomTom Green charging light on but wont switch on
I have a TomTom one which does not switch on, you see the green charging light but otherwise dead. Tried resetting without any luck. If I leave it for a few days it will then work fine for weeks and then the problem will return. This green light problem would appear to be quite common across a number of TomTom models, does anybody know the cause?
anothergo is offline
Old 03-03-2008, 6:31 PM   #2 (permalink)
Thanks: Gave 38, Got 29
Re: TomTom Green charging light on but wont switch on
Have a look here mate.......http://www.satnav-shop.com/index.php?page=greenLight
TeamGers is offline
Old 04-03-2008, 9:54 PM   #3 (permalink)
Originally Posted by TeamGers View Post
Interesting but I dont think it explains my fault
Old 05-03-2008, 8:21 AM   #4 (permalink)
Thanks: Gave 5, Got 34
My TomTom One does this now with the new software.
Remove (or just unclick) the SD card from its socket. Then try to turn it on. Then plug the SD card back in. If it didn't turn on before, it should do now.
I have to do that on battery power always. If it's plugged in before I try to switch it on, it works fine. No idea why.
ben.bayliss is online now
Old 05-03-2008, 6:53 PM   #5 (permalink)
This would appear to be a very common fault. Mine is over 12 months old so no comeback on TOMTOM. I'm sure with the right knowledge it could be fixed.
Old 06-03-2008, 10:16 AM   #6 (permalink)
My Tom Tom One Version 2 with the SD Card had exactly the same problem as Ben.baylis. Take out the SD card, put it back in and then it will switch on. The interesting thing is that if I put any other SD card in rather than the TomTom one, it would always switch on!! I found that I had to reset but not just for 15 seconds, more like 25 seconds. Then it has kept working as it should. Why? Who knows? When I spoke to Tom Tom support they said they had not heard of the problem!!
survey is offline
charging, green, light, switch, tomtom
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Sky+ box green light? ian dem Sky and Sky+ 3 29-02-2008 12:05 AM
SKY HD box wont switch on! martyates77 Sky HD 1 27-05-2007 5:25 PM
TomTom One V2 charging bradbell Satellite Navigation (Sat Nav) 1 22-05-2007 4:43 PM
N73 wont switch on mattals Mobile Phones and PDAs 1 22-03-2007 10:37 AM
My amp wont switch on help holty2503 Integrated AV Amplifiers and Receivers 3 22-09-2006 9:52 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
