AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Satellite Navigation (Sat Nav)
LinkBack Thread Tools Display Modes
Old 29-02-2008, 10:14 PM   #1 (permalink)
eBuyer NaviGo GPS mains charger.
If people are still struggling finding a mains charger for the NaviGo why not try a Motorola mobile charger.
I have been using one that came with a Razor with the mini USB connection & it seems to do the job just fine.
kazam401 is offline
Old 11-03-2008, 8:55 PM   #2 (permalink)
Thanks: Gave 0, Got 2
Re: eBuyer NaviGo GPS mains charger.
Thanks for the tip. The Motorola charger worked fine for me as well.
dashforth is offline
Old 12-03-2008, 12:06 AM   #3 (permalink)
What kind of charge speeds are you getting. USB on pc takes over 10 hours for a full charge which is a bit of a joke.
unicron is offline
Old 12-03-2008, 5:25 PM   #4 (permalink)
Thanks: Gave 1, Got 1
I'm using an old Uniross UNI505R adaptor which charges the SY885 to full (green light) in a couple of hours.
jim157 is offline
Old 14-03-2008, 11:16 AM   #5 (permalink)
Thanks: Gave 1, Got 0
I am using the Razr charger but had it on all night and the charge light is still not Green.How long does it usally take with this charger
Bigc
bigc136 is offline
Old 14-03-2008, 2:56 PM   #6 (permalink)
The 5.7v nokia charger works a treat too, so I'm told.
I've not checked what the car charger gives out yet.
trickydickie is offline
Old 14-03-2008, 3:14 PM   #7 (permalink)
Thanks: Gave 27, Got 57
Can confirm Nokia will charge did mine last night
LG RZ42PY10X Plasma, Yammy A595 Amp,B&W CC3 centre Kef Coda 7 fronts
Mission 73 surrounds, Pioneer DV400 DVD Player (multi-region)
Crystal Xbox (modded with X3 + 250gig HDD)
NTL Cable & Broadband
Kebabhead is offline
Old 15-03-2008, 11:55 AM   #8 (permalink)
Tony Pickard's Avatar
Thanks: Gave 2, Got 0
I bought something similar to this for my Ipod, just a basic 3 pin plug with USB conversion, would this be suitable to charge the Navigo straight from the mains.
http://cgi.ebay.co.uk/5-Volts-USB-Ma...em350035922614
Tony Pickard is offline
Old 15-03-2008, 1:29 PM   #9 (permalink)
Thanks: Gave 20, Got 63
Yes, all USB devices including the NAvigo use 5volts. That one doesn't define its current output though, 1.5to 2A are the most useful and will charge faster via USB than any low current device. Real USB ports are constrained by specification to provide a max of 0.5A.
alpine101 is offline
Tony Pickard (15-03-2008)
Old 16-03-2008, 12:55 PM   #10 (permalink)
The adapter i have says on the plug
" AC/DC Adapter
INPUT AC 100-240 v 50/60 Hz 3W
OUTPUT DC 5v-5.5v 400-500mA "
Would this be ok to charge the Navigo fromm the mains then. I hate anything to do with electrics....lol
Old 16-03-2008, 4:03 PM   #11 (permalink)
Thanks: Gave 41, Got 66
" AC/DC Adapter
Yes it will, but the current rating is no better than USB, so you can expect a long charge time.
peskywinnets is offline
Tony Pickard (17-03-2008)
Old 19-05-2008, 9:55 PM   #12 (permalink)
There is something odd about this charger business - the two mains ones I've tried make a dodgy connection with the Navigo (it appears the plug is physically identical to the in-car charger included) - its possible to use them but care needs to be taken that they are connected ok and the red light is lit on the Navigo. The best has been a switching mode power adaptor from Maplins UK now £8.99 - delivers 5 volts exactly, regulated and claims 2500mA output – very high compared to usb. Although the plug looks right the connection isn’t perfect.
I also have an original and newer lightweight express Nokia power adaptors - the latter says 5.7V/800mA – but the volt output is far higher (without load) more like 7V – therefore I’m fearful of using it.
There's something odd about the charging - if you interrupt it when fully charged (green light) and without turning the gps on and reconnect the charger (or usb) it restarts the charge at full charge level again (red light)... and takes hours to go out. Its easier to understand on the usb as the current is so low from these. I have seen this happen before on chargers that just rely on time for charging, but I thought this was different. Or am I missing something.
But on the car the red charging light goes out almost immediately as the internal electronics step down to trickle charge shown by the green light. What is so different about the car charging setup? There is no dodgy connection either, however much the cable is waggled. Could the voltage output of the in-car cigarette lighter charger lead be delivering a far higher voltage - don't tell me its shoving out 12 V !
Any ideas, help or comments would be appreciated.
Rgds., Roy
RoyTom is offline
Old 21-05-2008, 4:19 PM   #13 (permalink)
I used my Ipod charger but it has not turned the red light green to show its fully charged, but was ok for emergency use.
freddysmith is offline
charger, ebuyer, gps, mains, navigo
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Navigo Sat Nav (ebuyer) Stevebarton2 Satellite Navigation (Sat Nav) 4 19-02-2008 6:07 PM
Mains USB Charger dixiemax Portable Music (MP3, iPod etc.) 2 08-06-2007 2:06 PM
Navman F20 mains charger DigitalDuke Satellite Navigation (Sat Nav) 2 05-02-2007 1:21 PM
Pda mains charger kellaken Mobile Phones and PDAs 4 19-12-2006 12:54 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
