Originally Posted by morleymackam
I realise that but it's a bit awkward. The amount of times it's said to turn right but then there are 3/4 other turn offs before mine. I end up watching the distance counting down.
The i3 said 'in 200m turn right' then 'turn right' at the turnoff.
I have the "250". I expect the inbuilt program is the same for the "200". The first audible instruction depends on your speed. The faster you are going; the more distance to the turn will be given. Do not worry about other possible turns before your turn. You are normally given 3 warnings, with the final one being, say, "turn left". However; if the inbuilt map is not accruate; the junction may not be exactly where the Garmin says it is. Use the signpost too.
