AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Satellite Navigation (Sat Nav)
LinkBack Thread Tools Display Modes
Old 27-02-2008, 7:18 AM   #1 (permalink)
Thanks: Gave 37, Got 2
Check this out
Phone sat nav or stand alone check this.
readymix is offline
Old 27-02-2008, 8:58 AM   #2 (permalink)
Thanks: Gave 40, Got 133
Re: Check this out
And your point is ? ? ?
bsuttie is online now
Old 27-02-2008, 9:02 AM   #3 (permalink)
CloggyNL's Avatar
Thanks: Gave 73, Got 84
Re: Check this out
That screen is far too small to be any use as a Sat Nav
CloggyNL is online now
Old 27-02-2008, 11:09 AM   #4 (permalink)
Re: Check this out
And my point is what good is Garmin???. if its takes that long to get a fix. Who looks at the screen on sat nav you are supposed to look at the road, or am I missing something.
readymix is offline
Old 27-02-2008, 12:48 PM   #5 (permalink)
Thanks: Gave 11, Got 6
Re: Check this out
Sounds like you did a cold start which always takes longer, and I would expect it to tell you the speed limit if you were speeding.
nitelife is offline
check
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
