23-02-2008, 8:50 AM
#1 (permalink)
Thanks: Gave 15, Got 70
Need new Satnav
I have just sold my 4 year old parkardbell gps400 and i'm looking to get something more up to date.
I'm now unsure what to go for ,my max budget is £120.
I was thinking tomtom one v3 but the idea of internal memory only is putting me off a little,how many updates will it take before its full.
What else could i be looking at ,i only sold the gps400 due to the total lack of support.
Thanks.
Panasonic TH-42PWD8BS plamsa,Oppo 971h dvd,Targa DRH-5100x dvd/hdd pvr,Humax pvr-9200t freeview pvr, Dreambox Dm7000s satellite pvr ,Sony ST-RDB 1080 av amp, Canton cd100, cd50,cd10 speakers
, Svs Sb12+ sub woofer
23-02-2008, 4:23 PM
#2 (permalink)
Re: Need new Satnav
I need to order something this weekend,i'm thinking
Garmin Nuvi 200w
Tom tom one v3
mio 220
anything else
23-02-2008, 6:42 PM
#3 (permalink)
Thanks: Gave 0, Got 2
Re: Need new Satnav
Becker 7934 Traffic Assist Highspeed?
23-02-2008, 7:34 PM
#4 (permalink)
Re: Need new Satnav
 what
23-02-2008, 9:47 PM
#5 (permalink)
Thanks: Gave 3, Got 1
Re: Need new Satnav
I'm more then happy with my Tom Tom One.
24-02-2008, 7:08 AM
#6 (permalink)
Thanks: Gave 34, Got 51
Re: Need new Satnav
Inside Auto Express dated 20-26 Feb they have reviewed 16 Sat Navs. The Garmin Nuvi 200 at £129 came third overall and first at that price point. The widescreen version costs only £10 more.
24-02-2008, 7:51 AM
#7 (permalink)
Re: Need new Satnav
The garmin seems a good buy for the money but i'm unsure about the support.
Taffy do you have the v3 ? how much of the of the internal memory is left over?
Thanks.
24-02-2008, 5:17 PM
#8 (permalink)
Re: Need new Satnav
After a lot of looking i opted for the tomtom one.
25-02-2008, 12:48 PM
#9 (permalink)
Thanks: Gave 5, Got 8
Re: Need new Satnav
I am going through the same heartache!
I intend to use the device in the UK and Ireland BUT would like to be able to load some US maps for my hols in the summer.
I guess that the V3 512M internal ONLY memory will not be big enough for me, and no SD card option.
Can anyone comment on the best sub £120 sat nav with Sd card for extra maps.
Mark.
25-02-2008, 3:35 PM
#10 (permalink)
Re: Need new Satnav
Halfords are doing an offer of the Garmin Nuvi 200 gift pack which comes with a free leather case for £119.99. The normal price is £129 without a case. The Garmin has a Sd card slot http://www.halfords.com/webapp/wcs/s...tegoryrn_80866
26-02-2008, 12:44 PM
#11 (permalink)
Re: Need new Satnav
But the Garmin maps seem to cost a fortune...
I only want florida, but need to but all of North america >$130, a florida tom tom map costs around $30
Can you get more localised maps for the Garmin?
Incidentally Amazon are selling Nuvi250's for about the same priceas the 200 in halfords, albeit without the travel case.
Mark.
26-02-2008, 7:01 PM
#12 (permalink)
Re: Need new Satnav
I have just got my tomtom one and can highly recommend it , i have done all the updates online using the software from the totmtom.
After the update it manages to lock onto satellites within 15 seconds inside the house,very simple to use ,much better than i was expecting.
For anyone wanting to know it uses 188mb of the 512mb.
Vogon64 ,why not try and get tomtom one version one or two with the sd card slot.
27-02-2008, 12:20 PM
#13 (permalink)
Re: Need new Satnav
I suppose I am a bit of a snob, and even when trying to buy the "cheapest" sat nav I still want the latest version of it...
Can anyone tell me what was added/removed (other than the SD card slot) when tomtom one went from V2 to V3.
So I can figure out what I am missing out on if I buy a V2.
Mark
Mark.
27-02-2008, 12:29 PM
#14 (permalink)
Re: Need new Satnav
Can anyone tell me what the achievable capacity of the V3 512mb really is.
How much of the memory is reserved, or needed by other things such as routes, way points, POI (eg speed cameras) etc. etc.
If I see an additional map quoted at 237mb will it fit on the V3 UK and ROI without having to remove the UK and ROI maps.
Mark.
27-02-2008, 5:39 PM
#15 (permalink)
Re: Need new Satnav
On mine it has 159mb used and 329mb free ,i did delete the foreign voices though , all the voices together added up to around 50mb ,its now at 10mb with loads of celeb voices.
