AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Satellite Navigation (Sat Nav)
LinkBack Thread Tools Display Modes
Old 22-02-2008, 11:56 PM   #1 (permalink)
Sat Nav that accepts GPS co-ordinates
can anybody advise whether there is a Sat Nav that will allow the input of GPS co-ordinates as well as Postcodes and address details.
We want to do some wild camping in France and the only detailed information other than the town is the GPS location.
We currently have a Tom Tom 700
Motorhomer is offline
Old 23-02-2008, 11:51 AM   #2 (permalink)
Thanks: Gave 0, Got 7
Re: Sat Nav that accepts GPS co-ordinates
I should think you already can on your 700 (I can on my Go 520), but maybe your firmware version is too old? Don't you have a choice after "navigate to" that says "longitude and latitude"?
I think this has been a feature from firmware version 6 and above.
Svein is offline
Old 23-02-2008, 1:03 PM   #3 (permalink)
retrogameman's Avatar
Thanks: Gave 38, Got 105
Depending on how wild you are going and how much you want to spend.Tomtom 6 on the pda i know supports gps locations as i have used it myself.Another application if you are going for really "wild" is memory map which uses ordanance survey maps.I know that this is rather expensive but i believe they provide a trial version.
retrogameman is offline
Old 23-02-2008, 1:34 PM   #4 (permalink)
Thanks: Gave 29, Got 247
MioMap also allows you to input coordinates
Look at the Navigo £60 thread
pjclark1 is offline
Old 23-02-2008, 5:16 PM   #5 (permalink)
Thanks: Gave 2, Got 18
My garmin 250 accepts Lat/Long. Look in the Tom tom manual!
ronlizpatsimon is offline
accepts, coordinates, gps, nav, sat
Refbacks are On
Thread Thread Starter Forum Replies Last Post
where accepts paypal? pags payback Movie Suppliers and Technology 4 01-06-2007 12:29 PM
Anyone got a TV that accepts 24Hz from the PS3 for Blu Ray? Screamer LCD Televisions 4 29-05-2007 2:15 PM
TV only accepts scart - what's the best connection I can get ? Decadent Fool Interconnects, Speaker Cables and Switches 12 17-01-2007 9:08 AM
LCD that accepts 1080p via component or VGA? BYF LCD Televisions 2 27-09-2006 8:21 AM
Is there a tv that accepts 1080p 50/60hz? Rob20 High Definition TV Hardware 15 21-08-2005 6:07 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
