Hi all
I have HTC Touch Cruise running TomTom 6 (6.032v 8355) with western europe map v6.75 1049.
My problem is i cant do a full 7 digit postcode search, i only get to put in 3 digits, I have been told i should have a postcode file which i got Direct from TomTom using this link http://www.tomtom.com/updates/great_...postal_all.zip
I then followed instruction on where this file goes.
If you can't search for postcodes in the UK or the Netherlands, do the following:
1.Exit NAVIGATOR by tapping Exit application in the main menu.
2.Open File Explorer on your Pocket PC.
3.Go to My Device and then select Storage Card or SD card.
4.Tap and hold the folder ZIP and then select Copy.
This folder contains the postcode database.
5.back to My Device and then open My Documents.
6.Tap and hold anywhere on the white screen and then select Paste.
This copies the Folder ZIP from the SD card to the internal memory.
The full postcode search should now work for addresses in the UK and the Netherlands.
After doing this I STILL CANT DO A 7 DIGIT POSTCODE SEARCH.
Can anyone else tell me what to try or confirm to me i have the right files in the right places.
I really appreciate anyones help.
Thankyou
