AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Satellite Navigation (Sat Nav)
LinkBack Thread Tools Display Modes
Old 18-01-2007, 9:44 PM   #1 (permalink)
Thanks: Gave 1, Got 0
TomTom 6 onto Orbit phone/PDA installation problems
Guys, have gone for the Orbit phone/PDA (with built in GPS) and trying to install TT6 onto the Micro card. first attempt no maps found error message. Has anyone had the same problem? or has anyone got TT6 working on their Orbit or similar phone/PDA?
GaRyBbRaY is offline
Old 19-01-2007, 9:10 PM   #2 (permalink)
Thanks: Gave 3, Got 43
Re: TomTom 6 onto Orbit phone/PDA installation problems
I've just put TT5 onto my Navman . I followed the instructions for the installation but on starting the program got No Maps found. I was told to put all the files into one folder .I dont think this is the case .This is what I read elsewhere :
NORMAL SETUP PROCESS
1) COPY ALL THE FOLDERS AND THE START.EXE OFF THE DVD TO YOUR MEMORYCARD WHILST IT IS INSERTED IN YOUR PDA.
(DO NOT PUT THEM INTO A FOLDER ON YOUR MEMORYCARD)
2) IF YOU CAN NOT FIT ALL THE MAPS ON TO YOUR MEMORYCARD LEAVE SOME MAPS OFF.
hope this helps
I followed these instructions and it found the maps straight away .
Technomate 1500+* Lenson 1m*Geotrack Positioner*Panasonic Th37 Plasma*Panasonic NV-GS11*Sharp VL-WD450 *C500*PIN570*Nokia770*Ubiquio401&501*Navigo sy-895*
rickyt is offline
installation, orbit, phone or pda, problems, tomtom
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
