17-01-2007, 6:24 PM
#1 (permalink)
Thanks: Gave 1, Got 0
TomTom One V2 - Problem
Hi all
I got a TomTom one V2 for christmas i am very pleased with it, although one slight thing i have noticed is when the battery runs completley flat, and i then charge it, it does not switch on. i have to reset it for it to come on.
This only happens when the battery is dead.
Any one else suffer this?
Chris
18-01-2007, 5:35 PM
#2 (permalink)
Re: TomTom One V2 - Problem
Just a quick follow up, if anyone has a tomtom one v2 and it runs out of battery completely, when they start to charge it can they turn it on as soon as its plugged into the mains?
Thanks all
Chris
20-01-2007, 7:18 AM
#3 (permalink)
Thanks: Gave 5, Got 0
Thanks all
Chris
I too had this problem but then I downloaded the latest firmware via TomTom home OK now
Hope this helps
PaulR
20-01-2007, 12:03 PM
#4 (permalink)
what version firmware do you have on yours now paul?
and thanks for your reply
20-01-2007, 3:09 PM
#5 (permalink)
Thanks: Gave 0, Got 7
I have just installed version 6.560, a bit to early to tell if its done the trick.
21-01-2007, 4:57 AM
#6 (permalink)
6.52 Im sorry but I didnt know that there was a newer version I will check this out Just updated to 6.56 Haven't tried it yet
PaulR
22-01-2007, 11:32 AM
#7 (permalink)
Thanks: Gave 15, Got 0
PaulR
Does any one know what is included in 6.56?
22-01-2007, 8:26 PM
#8 (permalink)
23-01-2007, 10:09 AM
#9 (permalink)
How good is that! Fantastic, really please I went for the TT v2 now.
31-01-2007, 7:45 AM
#10 (permalink)
Thanks: Gave 364, Got 900
I have the same problem. Does updating the firmware definitely fix this? I'm contemplating whether to return it for a new one?
31-01-2007, 10:09 PM
#11 (permalink)
It seems to have improved the problem but I wouldn't say its fixed completely.
01-02-2007, 9:24 AM
#12 (permalink)
I see. I'm just concerned that if I got it replaced there would be an exact same issue with the replacement unit. It seems farcical that you have to take a paperclip wherever you go!
02-02-2007, 6:00 PM
#13 (permalink)
it seems to have fixed my problem
03-02-2007, 12:39 PM
#14 (permalink)
Okay thanks Chris - I'll give it a bit more time before I consider returning it.
04-02-2007, 2:56 PM
#15 (permalink)
No probs matey
