Help upgrading card size Tom Tom 510 Go
Help required, Tom Tom 510 Go, have run out of update space on the supplied 256mg SD card, have got a 1gb card have tranfered all files via update, and it will not load up maps, is asking me for my activation code which have & have checked it is correct on the TT code site,but it says it is the wrong code, on entering it.
do you have to do something else to change cards, can find no info on doing this but you must be able to or you run out of update space.
Selwyn
