Originally Posted by dj teknovibe
What about the accuracy of the unit,
GPS is suppose to be acturate to 2 metres, a road is about 10 meters wide.
It may put you on the wrong road in the initial start up, but as it picks up more satalites it will get more acurate.
or the fact that tom tom makes very bad mistakes quite often
What do you class as very bad mistakes?
If it says go left and it leads over a cliff don't go left. Use a combination of looking at the map and instructions.
All sat navs should be sold with a big sign that says, "must use common sense aswel"
and sends you totally the wrong way.
If you know know the right way, why are you using a sat nav?
You can choose how you want the tomtom to direct you. Shortest, quickest, avoid motorway, walking etc. Also if you don't like the original route, you can ask it to recalculate one. Or if you want to go a certain way you can set waypoints.
