AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Satellite Navigation (Sat Nav)
LinkBack Thread Tools Display Modes
Old 01-01-2007, 10:36 PM   #1 (permalink)
Thanks: Gave 17, Got 36
TomTom 910 problem
Had my 910 for a few days now. Just got it out to plan a journey for tomorrow and it won't switch on! Battery is fully charged before anyone asks... any ideas?
craig777 is offline
Old 01-01-2007, 10:52 PM   #2 (permalink)
Re: TomTom 910 problem
Have you tried doing a reset on it ?
Arcam AV8, Arcam P7, Arcam FMJ-CD33, Arcam FMJ-DV27A, Sony DVD 7700, Velodyne SPL1200 MkII ,Proac Studio 150, Fujitsu P42XHA58EB Plasma, Sony PS3
Rotorsport is offline
Old 01-01-2007, 11:18 PM   #3 (permalink)
Tell me how and I'll try.
craig777 is offline
Old 01-01-2007, 11:33 PM   #4 (permalink)
If you look in at the back just above the metal contacts you will see a small semi-circle, at the bottom is the reset button. You will need something like a needle to press the button.
Hope this helps.
craig777 (01-01-2007)
Old 01-01-2007, 11:43 PM   #5 (permalink)
Hope this helps.
I see it... just!
Would pressing the reset button work even when the unit is off such as mine? Doesn't this just reset the unit when it's on and in a 'freeze' state?
craig777 is offline
Old 02-01-2007, 12:40 AM   #6 (permalink)
per-Sony-fied's Avatar
Thanks: Gave 47, Got 104
Originally Posted by craig777 View Post
I see it... just!
The easy way is try it! Wont do no harm.
How do you know the battery is fully charged if the unit wont switch on? Merely charging it does not imply it is charged.
FYI energising the unit requires the ON button to be held down for at least 2 secs for it to turn on and then wait some for it to come alive.
per-Sony-fied is offline
Old 02-01-2007, 8:35 AM   #7 (permalink)
Well the unit was fully charged when I last used it on Saturday evening. I put it away in it's pouch on Saturday night and hadn't used it until last night when I tried switching it on to plan a route in advance... I can't believe the battery would of lost it's charge within 48 hrs. ??
Edit... just done a reset and it now works as normal, so problem solved - hopefully!
Thanks guys.
craig777 is offline
910, problem, tomtom
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
