Originally Posted by bazfoster
Does this work with a 2gb (Sandisk) SD Card anyone?
Mines a kingston 2gb with no problems
Pauleylad - there should be no reason why you shouldn't just load it up via Activesync. It maybe Navman but it is just a Windows Mobile PDA with built in GPS reciever.
krelisys - Mine worked out of the box, just put the supplied 256mb MMC card with maps in and press the SmartST button. There is a soft reset button on the bottom left of unit but failing that take it back. The Halfords staff made it very clear if there are any problems I could take it back.
I've now gone to TTN6 also and I am undecided which is the better. TTN5 or 6 is much nicer GUI and Postcode search is a lot better but SmartST seems more accurate in placing you. ST is also integrated into the unit so you can press the buttons for zooming and menus/display, but TTN can be fully operated by your finger on the touch screen so you can use it in situ which makes a lot more sense than struggling with the stylus when the unit is mounted.
Either way I'll leave both on there to choose from while enjoying playing Wolfenstien3D on it....brings back memories
