AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Satellite Navigation (Sat Nav)
LinkBack Thread Tools Display Modes
Old 31-12-2006, 2:40 PM   #1 (permalink)
Thanks: Gave 5, Got 7
TT 510 ~ home charger base
Just got a TT510 and the home base/charger looks a bit 'iffy'. The charger puug into the base is very loose - falls out with hardly any effort and the TT dosent seem to be a great fit on the stand, its hard to get the charge light to come on.
Should the TT 'click' on to home base like it does the sereen dock?
Anybody else got any experience of this?
~ Hitachi 42PD7200 ~ Yamaha DSP-A2 ~ B&W 684 front ~ Mourdaunt-Short MS302 Rear ~ B&W HTM62 Ctr ~ Monolith DF ~ Sky+ ~ Arcam DV88+ ~ Philips DVDR70 ~
happhhitachi is offline
Old 31-12-2006, 5:22 PM   #2 (permalink)
per-Sony-fied's Avatar
Thanks: Gave 47, Got 104
Re: TT 510 ~ home charger base
The 510 does click onto the PC base unit but it is not very solid. It is easily clicked into position by pressing the 510 and pc base unit together.... you can hear them click. To be honest it does not have to be that secure as the weight of the item holds the unit on the pc base unit.I can pick my 510 up and shake it without the base unit falling off. It's primary use is only for transfering data.
For charging the unit it comes with a seperate home charger that plugs into the screen mount.
per-Sony-fied is offline
510, base, charger, home
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
