AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Satellite Navigation (Sat Nav)
LinkBack Thread Tools Display Modes
Old 29-12-2006, 10:58 PM   #1 (permalink)
Thumbs up Which Motorcycle Sat Nav
Greetings from a newbie.
Am doing research to try and decide which sat nav for my motorcycle tour of Europe next year, well nearly this one really !
The Garmin 2610 looks ok and good price but has no internal battery which I think I will need at some point.
The new motorcycle specific ones are too expensive so was thinking of a Navman maybeaan 1520 ???? as it looks like it will do the job ok but is not waterproof. I can always get a waterproof case so that's nor really a problem, but do you feel it is rugged enough?
Secondly most pics I have seen except one seem to indicate there is no external antenna, only this one pic I saw it looked like something flipped up on the back, anyone know if the antenna sit's proud or is it anternal?
look forward to any replies or advice.
Bananaman1 is offline
Old 30-12-2006, 8:36 AM   #2 (permalink)
Thanks: Gave 5, Got 4
Re: Which Motorcycle Sat Nav
The TomTom bike version seems reasonable? I would go for one if it had a speaker so that I could also use it in the car...
come on you blues
42PWD7, (a very cheap) Sony DVD through Sky box and JS RGB into VGA, sound provided by Teac Ref 500 amp and a pair of Mission speakers. All controlled via a Harmony 655 (not any more, it bit the dust )
dickst3 is offline
Old 31-12-2006, 7:47 PM   #3 (permalink)
Thanks: Gave 5, Got 27
I've got an Orange SPV500 mobile phone that runs windows mobile. I have installed TomTom on it. It works fine coupled to a bluetotth GPS receiver. I put the phone and GPS receiver in the clear window of my tank bag. I can't hear the directions but to be honest you'd need a flippin' loud speaker for me as I always wear earplugs. The Sat-nav works fine as it counts down to the next waypoint on the route so you don't need to keep looking down too much.
It also works out a new route to the destination within a minute or so if you miss a turning. I've done this on purpose to test it out. Considering I got the phone from work for nothing, downloaded the TomTom for nothing too and only paid £38 for my Holux 321 GPS receiver I'm well pleased with it
The thing with a phone base sat-nav is you could hook it up to earphones and listen to the directions that way.
nitram_tpr is offline
motorcycle, nav, sat
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
