AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Satellite Navigation (Sat Nav)
LinkBack Thread Tools Display Modes
Old 29-12-2006, 9:12 PM   #1 (permalink)
Thanks: Gave 2, Got 1
tomtom 510 speed camera warning
Can anyone tell me how the TomTom 510 warns you that you are approaching a speed camera, does it give a beep / speak a warning or simply flash on screen.
hbe100 is offline
Old 30-12-2006, 8:24 AM   #2 (permalink)
clockworks's Avatar
Thanks: Gave 32, Got 170
Re: tomtom 510 speed camera warning
As standard, it will flash on the screen and play a warning beep.
I beleive that you can add extra files to change the warning sounds.
Panasonic TH-46PZ81B, Arcam AVR350, Linn LK100, Naim NAP110, Quad L-ites, PS3, Samsung 850, Sky+, Humax 9200T, Panasonic E50, Harmony 1000, Pixel Magic HD-MB200, M-Audio Flying Cow DAC, Pronto TSU9600, Mac Mini, iMac
clockworks is offline
Old 30-12-2006, 2:59 PM   #3 (permalink)
Thanks: Gave 4, Got 0
We are just setting up the 710 and i was asked a question similar about the cameras. Do they come on automatically set up or do you have to download them?
TrevUK is offline
Old 30-12-2006, 4:46 PM   #4 (permalink)
clockworks's Avatar
The TomTom camera database is supplied, but it's not very good. I downloaded the pocketgps camera database.
Old 30-12-2006, 9:24 PM   #5 (permalink)
per-Sony-fied's Avatar
Thanks: Gave 47, Got 104
The TomTom camera warning database only has a 1 month trial period from new and will give you a small speed box outlined in red about 6mm2 with a advanced beep warning of about 300yds. It works well enough but sometimes it does not know about a installed camera and sometimes thinks there is a installed camera when there isnt! So in all instances best to try and keep an eye on the road and where the sat nav thinks the camera's are.
per-Sony-fied is offline
Old 30-12-2006, 9:26 PM   #6 (permalink)
They work out of the box for 1 month no setting up required.
TrevUK (30-12-2006)
Old 30-12-2006, 10:22 PM   #7 (permalink)
Best to buy the pocketgspworld one then?
TrevUK is offline
Old 31-12-2006, 2:19 AM   #8 (permalink)
Thanks: Gave 9, Got 61
I spent £20.66 for 1yr of the official tomtom database and am very disapointed.
Tomtom have changed the way it's implemented into the software and it's now not part of P.O.I. (points of interest)
This means there's no opportunity to change the warning sound or the distance. Your stuck with a single 'beep', which doesn't stand out.
I gave the pocketgps one ago, and it's 1000% better! They all appear in P.O.I. with 20+ different types of camera listed, all with there own icon. Plus each type of camera can be set independantly with choice of sound and distance before warning.
simon1 is offline
Old 03-01-2007, 6:08 PM   #9 (permalink)
Thanks: Gave 5, Got 7
Just got a TT510, using the installed camera base but looking at other options. However it looks like this is quite a drag getting all these POIs to the TT and then keeping it all updated. Is it necessary to redownload the databases each month/time they are updated and set the warnings all over again or is there an easy update technique?
All opinion/comment/suggestion welcome.
~ Hitachi 42PD7200 ~ Yamaha DSP-A2 ~ B&W 684 front ~ Mourdaunt-Short MS302 Rear ~ B&W HTM62 Ctr ~ Monolith DF ~ Sky+ ~ Arcam DV88+ ~ Philips DVDR70 ~
happhhitachi is offline
Old 03-01-2007, 11:41 PM   #10 (permalink)
The files simply need to be copied to your UK map folder (takes all of 5 seconds). It's up to you how often you update. I'm not aware of any other way to update the files.
simon1 is offline
Old 05-01-2007, 7:53 PM   #11 (permalink)
Thanks Simon, just got the pocketgps database and install was easy enough although setting up all the warnings individually was a bit of a fag - but i understand that i wont neeed to do this after installing every update.
FWIW the on sereen ikons are IMHO clearer than the Std TT ones.
The file orginisation on the TT is a mess, they need to sort that lot out, no orginisation whatever, everything just dropped into the map folder.
Quite pleased so far but SatNav has a long way to go, its very Heath Robinson, whats on my wish list:
1) More battery life - like 3 weeks the TT510 reminds me of the first mobile phone I had about 12 years ago, good for a day, just about.
2) Why cant they get into bed with Nokia/Motorola/Ericsson (whoever) and use the same battery/charger/connections as mobile phones.
3) Get it to talk to the cars electronics. night view when you swith lights on, shut up when you put indicators on, use car speakers, connect to external antenna. all without connecting a load of seperate wires.
4) Common mount/connections and can we please have something better then a sucker. Why cant they get togather with the car makers and have bracket built in thats easy to remove/hide.
Old 05-01-2007, 8:08 PM   #12 (permalink)
Thanks: Gave 9, Got 2
now thats what I call good thinking
snowey is offline
Old 05-01-2007, 8:44 PM   #13 (permalink)
You cannot change the beep to a better noise that will certainly alarm you of a speed trap? Thats odd, seems like if that was a feature TomTom would want you to make the most of it. Hmm...
ZiggyStardust is offline
Old 05-01-2007, 9:21 PM   #14 (permalink)
The good news for those of you with the 510, is that Tomtom are about to release 'Car Connect'. This will become available in the next few weeks.
See here for price/availability.
simon1 is offline
Old 12-01-2007, 8:36 PM   #15 (permalink)
That is a great feature for the 510. When is it going to be available?
510, camera, speed, tomtom, warning
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
