AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Satellite Navigation (Sat Nav)
LinkBack Thread Tools Display Modes
Old 28-12-2006, 4:57 PM   #1 (permalink)
Thanks: Gave 5, Got 4
whats a good wireless bluetooth gps unit
Hi whats a good wireless bluetooth gps unit to use on pocket PDA for tom tom v 6 Thanks for any info
peace1 is offline
Old 28-12-2006, 5:02 PM   #2 (permalink)
obiwan's Avatar
Thanks: Gave 0, Got 5
Re: whats a good wireless bluetooth gps unit
http://www.globalpositioningsystems....306b993bcd9dc0
i use the fortuna clipon
very good
DEVONshots
MY YOUYUBE CHANNEL - LOTS OF STUFF FROM 2008 EDEN SESSIONS
flickr
xbltag: Temra
obiwan is offline
Old 28-12-2006, 6:32 PM   #3 (permalink)
Thanks: Gave 5, Got 27
I got a Holux for £36 from Ebay
http://stores.ebay.co.uk/holox-direct54
They were pretty good, speedy delivery and the unit works a treat with TomTom Mobile on my old SPV500
They only have Italian ones at the mo, but do a search on Ebay and you'll find loads of them on there.
nitram_tpr is offline
Old 28-12-2006, 7:49 PM   #4 (permalink)
Thanks: Gave 12, Got 7
I'm looking into this too....
Is it better to get a separate one or just get the GPS unit with the TT6?
I want to use it in a car and motorbike
the_sanguine is offline
Old 28-12-2006, 10:25 PM   #5 (permalink)
Hi what is it that we are suppossed to be looking at wen we are searching for a gps unit i.e. channels e.t.c. is it true the more channals the better it is ?
thank u for any info in advance
peace1 is offline
Old 28-12-2006, 10:55 PM   #6 (permalink)
Thanks: Gave 42, Got 96
I got this for Christmas:
http://www.scancom.co.uk/product.php...8f8a48e0efac13
Works fine with my Tom Tom 6 on my SE P990I. Great little unit. I parked up in work yesterday, put it on my dashboard and it picked up 10 satellites but I have yet to plot a long route with it. May get the chance to at the weekend.
apolloa is offline
Old 29-12-2006, 5:48 PM   #7 (permalink)
That looks cool. I was told elsewhere though that TT do all they can to try to make the SW work better with their own receivers though.
Is there any truth in that? Otherwise , I could save a packet....
Old 31-12-2006, 7:53 PM   #8 (permalink)
My Holux 321 I mentioned earlier works perfectly with my SPV based Tom Tom. The bumph with it says it'll synch up with 32 Sat's, whenever I look at the settings it's hooked up to 4 or 5.
The one thing is you have to turn the receiver on before you leave the house and let it synch up with the sat's first. If you turn it on when you are moving it will not synch at all. I would say it needs about 2 minutes to synch.
I use it on my motorbike in the clear window of my tankbag.
Old 31-12-2006, 10:45 PM   #9 (permalink)
"I use it on my motorbike in the clear window of my tankbag."
Yep...that's the plan
Old 01-01-2007, 10:35 AM   #10 (permalink)
per-Sony-fied's Avatar
Thanks: Gave 47, Got 104
Generally all Sat nav's do the same thing... i.e get you from A to B without to much hassle. To sieve out the good from the bad tho' there are a few things to look for.
1. Battery life
2. Processor speed (required for quick recalculation and instruction)
3. Satellite chipset (surf star III or similar). How quickly it logs onto a satellite. The TomTom 10 series uses 5 satellites. I believe earlier versions used 3. Using more does not make them more accurate just gives em more of a chance of a fix all the time.
4. Ease of use. Some give better spoken instructions like "Take the motorway" rather than "Take the next left" and some do "Take the M11 motorway!)
These are the basics but there's a lot more if you require them like bluetooth hands free,Speed cameras,Traffic congestion, calculation of routes,Navpix as on the Navman and how easy it is to set all your parameters for a journey.
You really need to read some reviews or go to some stores for a demonstration of what they can do.
per-Sony-fied is offline
Old 01-01-2007, 9:45 PM   #11 (permalink)
Can anybody recommend a good option in terms of GPS unit?
Old 02-01-2007, 10:44 PM   #12 (permalink)
Thanks: Gave 4, Got 25
I bought this bluetooth GPS receiver (although its cheaper now). Battery life is great, and never had any problems, and about the size of a mtachbox.
Ive also put route66 software onto my SPV M600 and it all works a treat.
http://www.mobilefun.co.uk/product/10939.htm
peterjspencer is offline
Old 03-01-2007, 11:53 AM   #13 (permalink)
They do a cheaper one too. A bit of a minefield isn't it!
Old 04-01-2007, 2:26 PM   #14 (permalink)
Wilf's Avatar
Thanks: Gave 19, Got 5
I can second the mobilefun SiRF III unit. Works very well with TT6, easy to set up, good battery life, even works in the house. Delivered less than 12 hrs after buying online with the cheapest postage option. Well worth the £45 + 2.50 pp IMO.
ran him out of town like a common pygmy
Wilf is offline
Old 10-01-2007, 7:52 PM   #15 (permalink)
Thanks: Gave 10, Got 4
Sorry to but in :-
I want to mount mine in the boot but understand that if the bluetooth connection is lost then the gps receiver shuts down to preserve power. I remember reading that there was a model which you could disable this feature so you could leave it hidden in the car, permanently.
Can anybody tell me which one it is?
Fulltopuk
Fulltopuk is offline
bluetooth, good, gps, unit, wireless
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
