AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Satellite Navigation (Sat Nav)
LinkBack Thread Tools Display Modes
Old 27-12-2006, 7:18 PM   #1 (permalink)
Smile Cheetah database to your tomtom. Help install
Can some one help and explain step by step how you set up speedcheetah to your tomtom. When on the website it asks you to download the poi converter. There are two options which are here.
POIConverter.zip Version 3.18, Size 1699KB
Contents: POIConverter_setup.exe, readme.txt, POIConverter.doc
POIConverter.zip Version 1.03, Size 1118KB
Which one do you select and then where do you go from here, i am new to this thanks.
Managers is offline
Old 28-12-2006, 5:15 PM   #2 (permalink)
Re: Cheetah database to your tomtom. Help install
I have found out how to do it, quite tricky but i got there in the end....
Managers is offline
cheetah, database, install, tomtom
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
