AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Satellite Navigation (Sat Nav)
LinkBack Thread Tools Display Modes
Old 23-02-2006, 4:43 PM   #1 (permalink)
Thanks: Gave 28, Got 19
Add SAT NAV to Nokia 6680
I have a new nokia 6680 and i want to add sat nav capabilities.
What do i need ??
To the best of my understanding i need a gps blueetooth device and tom tom software. Where can i get all these at a reasonable price. Any from your experiences is it worth the hassle ( i mean is it really usable on a phone) or should i just get a sat nav device like a tom tom ?
Anyone
kumamoto is offline
Old 23-02-2006, 5:24 PM   #2 (permalink)
Thanks: Gave 29, Got 247
a BT-77 bluetooth GPS receiver from ebay will cost about £50
then you will need the software route 66 or tomtom 5 mobile
seem to be the best.
(I use tomtom 5 mobile with my 6630 and it works 100%))
The best argument against democracy is a five-minute conversation with the average voter.
pjclark1 is offline
Old 24-02-2006, 1:48 PM   #3 (permalink)
Thanks pj
kumamoto is offline
Old 24-02-2006, 3:08 PM   #4 (permalink)
I use a Holux GPSlim with TomTom 5 mobile on my 6630 and it works a treat. The screen is big enough for the map and directions - although the little numbers telling you stuff like speed and total distance to go are a bit small, but no big deal.
TomTom sell the software and a decent GPS reciever, or you can get the stuff on ebay. But be aware there are some good GPS recievers and some not so good ones, so best read around a bit to see what you want and want to spend.
ivor.bigun is offline
Old 24-02-2006, 6:00 PM   #5 (permalink)
Thanks: Gave 1, Got 0
Anyway, bay always a GPS with a SirfIII chipset.
J_Adonis is offline
6680, add, nav, nokia, sat
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
