AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Satellite Navigation (Sat Nav)
LinkBack Thread Tools Display Modes
Old 14-03-2008, 10:49 PM   #16 (permalink)
Re: Plz Help With Garmin Streetpilot I3
Originally Posted by gilesme View Post
Time not being correct is linked to not navigating - it synchs when it locks on to enough satellites.
Try leaving the I3 on, in clear view of the sky (e.g. roof of your car) for a period of time.
Should hopefully clear the problem, and make it start quicker next time.
You could also try a factory reset (while powered up, hold down all 3 buttons on the front of the unit) - HOWEVER, you will lose installed custom POIs by doing this, so will need to reload.
Hope this helps. If you need a new one, I upgraded to Garmin 250 - very similar.
Okay i tryed the factory reset, no luck i tryed leaving it on top of my car for 1hour while i was fitting my new speakers 122watts hehe anyways there is still no luck, now i also downloaded Garmin City Navigator® Europe NT 2008 DVD installed all the maps on my garmin and now it says im loctaed in london lool but i surpose it will show me where iam if i ever do get a sat any more options maybe a upgrade software is 3.40 atm like. any beta soft out there?
cheers for replys.
50pounds is offline
garmin, plz, streetpilot
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
