AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Electronics > Satellite Navigation (Sat Nav)
LinkBack Thread Tools Display Modes
Old 15-01-2006, 8:19 PM   #1 (permalink)
tomtom300 problem
had tomtom300 6 months no probs .been updateing when notivated for new speed cams .did the last one early dec and ever since it wont start up . been intouch with tomtom support but very slow. been advised to load new version done this but still no good .
can press power button will start up , bar goes across screen loadind mem card then nothing just a picture of tomtom dashbord. can start with no card in and get annimation telling me to put card in ,i do this and the same happens. the only way to switch unit off when this occurs is to press the reset button underneath.
can anyone help me?
monkey tennis is offline
Old 15-01-2006, 8:21 PM   #2 (permalink)
Super Moderator
Thanks: Gave 172, Got 120
You have a back-up of your card that you can use, when all was ok?
Opinions given are my own and are not associated with avforums.
lynx is offline
Old 15-01-2006, 8:21 PM   #3 (permalink)
Thanks: Gave 1, Got 2
Have you tried reformatting the SD card and trying again
Matra is offline
Old 15-01-2006, 8:43 PM   #4 (permalink)
have no backup copy so what can i do . wont reformating wipe mem card.
Old 15-01-2006, 10:07 PM   #5 (permalink)
and what if i get one of these mem cards of ebay for £10-15 will it work or is there security software that stops u doing this
Old 18-01-2006, 5:16 PM   #6 (permalink)
problem solved . support line very helpful deleted all last know cam updates and worked fine . so one of the files was corrupt , causing probs. put cam updates back on and is workin fine.
i love my tom tom
problem, tomtom300
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
