Samsung Omnia i900 Firmware updates here
Old 29-12-2008, 6:01 PM   #1
MarkR's Avatar
9,312, Level: 23
Points: 9,312, Level: 23 Points: 9,312, Level: 23 Points: 9,312, Level: 23
Thanks: Gave 51, Got 20
Arrow Samsung Omnia i900 Firmware updates here
After hours and hours of trying to work out how to update my firmware on my Orange Omnia i900 I thought it would be a good idea to start a thread of any firmware updates for your current versions. My phone came with version BVHH1 and find below how I updated this:-
Orange firmware update for version BVHH1 to MSHJ1
Please note that this update is not from Orange but does work as it works perfectly on mine and all the others with this Firmware
I have had various issues with my current Firmware especially with very poor signal issues when on the move and limited battery life. My ROM version is BVHH1 and I am with Orange. Orange deny there are any problems with this Handset and were not prepared to do anything about it (Although my average bill is over £100 per month).
After extensive research I have now worked out how to update my current ROM version BVHH1 to MSHJ1. These are the instructions I followed from Member tigersden on Samsung-Omnia.org Forum below:-
After reading some good info on News I thought I would try it on my branded Orange Omina which had the following versions:
PDA: i900XXHH1/BVHH1
Phone: i900BVHH1
I was getting impatient waiting for Samsung to release an update for my version.
After the update the phone is unbranded
Heres what I did
1) Go to the official Smasung update site: Samsung Mobile
2) For the version check enter the following version MSHH1 you will then be able to download the official MSHJ1 updater.
3) Edit the following registry key on the Omina HKCU\ControlPanel\Version\CustomVersion to MSHH1
(The original keys value on mine was BVHH1_HH1 I just altered it to read MSHH1_HH1)
Check this setting has been stored by using the version checker in Start\Settings\System
4) Run the official updater.
If all goes correctly you should end up with the following versions:
PDA: i900XXHJ4/MSHJ1
Phone: i900XXHI5
Remember: Flashing is done at your own risk!
I hope this info may prove helpful to others.
If you do not have a reg edit program just type this url on your mobile PHM Registry Editor : Pocket PC Edition and then select download. Once you have done this from the Package Selection select 'Pocket PC 2000 (ARM)'. Simply install this from your mobile after download is complete. You can now open this program and alter the version.
michaeljones06 (05-11-2009), robinhood1701 (02-01-2009)
Old 01-01-2009, 4:55 PM   #2
2,332, Level: 11
Points: 2,332, Level: 11 Points: 2,332, Level: 11 Points: 2,332, Level: 11
Thanks: Gave 0, Got 5
Re: Samsung Omnia i900 Firmware updates here
Hi there. does anyone have a tried adn tested solution for flashing T Mobile. I currently have the dreaded BOHH5 version adn the battery drains faster than a siv full of water. Any updates would be appreciated. I have typed BOHH5 on the offical Omnia site they say i have entered an incorrect code - meaning they don't have an update version yet.... or so they say ??????
Old 02-01-2009, 10:53 AM   #3
4,428, Level: 15
Points: 4,428, Level: 15 Points: 4,428, Level: 15 Points: 4,428, Level: 15
Thanks: Gave 18, Got 13
Phone: i900BVHH1
Heres what I did
Phone: i900XXHI5
Hi Mark,
Am looking at an Omnia for my Vodafone upgrade,
had to smile when i read what you wrote -
"I have had various issues with my current Firmware especially with very poor signal issues when on the move and limited battery life. My ROM version is BVHH1 and I am with Orange. Orange deny there are any problems with this Handset and were not prepared to do anything about it"
Nearly the exact same thing happens over at Vodafone's forum!
Good idea, this thread, good insight,
thanks
MarkR (10-01-2009)
Old 09-01-2009, 6:38 PM   #4
1,944, Level: 10
Points: 1,944, Level: 10 Points: 1,944, Level: 10 Points: 1,944, Level: 10
Hi, first post just to let you guys know that the above method worked perfectly for me, from BVHH1 Orange UK firmware (yuck!) to MSHJ1. Cool - thanks for this, good work!
Old 09-01-2009, 6:44 PM   #5
MarkR's Avatar
9,312, Level: 23
Great really pleased it has worked for you too. I have certainly noticed a huge difference in longer battery life and the signal issue is a lot better although it still drops calls on occasion.
Be interested to hear your comments after you have tested it for a few days.
Welcome to the Forums by the way.
Old 10-01-2009, 1:29 AM   #6
1,643, Level: 9
Points: 1,643, Level: 9 Points: 1,643, Level: 9 Points: 1,643, Level: 9
these people appear to be keen on this update;
New Clean i900 Rom - WinMo @ MoDaCo
what I'd like to know is if I go through a procedure like this how would it affect my vodafone contract? especially my unlimited internet browser?
Old 12-01-2009, 9:51 PM   #7
biged1801
Posts: n/a
Hi Markr:
Just get my Omnia and have read a lot about the software upgrade, so decide to go for it.
However, will need a little help from you with this line:
"3) Edit the following registry key on the Omina HKCU\ControlPanel\Version\CustomVersion to MSHH1
(The original keys value on mine was BVHH1_HH1 I just altered it to read MSHH1_HH1)", if you can give me a "step by step" guide to do it I will appreciate it. So far, have been trying to find a way on my phone to do it, but without success.
Regards,
Edgar
Old 12-01-2009, 11:20 PM   #8
MarkR's Avatar
9,312, Level: 23
The only way you can edit this line is with a dedicated program that needs to be installed on your mobile. Here is how you do it:-
Step 1: Click on this link to download the PHM Registry Editor http://www.phm.lu/downloads/download...-2A4418802FD3} and then click on 'Download PHM Registry Editor : Pocket PC Edition'
Step 2: Select the 'Pocket PC 2000 (ARM)' version from the drop down menu.
Step 3: Once this has downloaded to your PC you then need to transfer this file over to your Mobile using Active Sync.
Step 4: From your Mobile locate the file you downloaded, this is usually best found by using File Explorer. To find this goto Start - Programs - File Explorer.
Step 5: Double click file and it will install PHM Registry Editor.
Step 6: You should now be able to edit the Registry Key.
Let me know how you get on.
Old 12-01-2009, 11:36 PM   #9
6,061, Level: 18
Points: 6,061, Level: 18 Points: 6,061, Level: 18 Points: 6,061, Level: 18
Thanks: Gave 1, Got 6
I updated mine this morning after seeing this thread with the how to
Does seems to be a little faster reacting and signal although still not great around home has improved slightly - that I've managed to have a call and finish it when I want. I think the problem I have in my location is I get a poor 3G signal so when it drops it goes to 2G calls seem ok, if I make a call when its on 3G quality is not the best.
Anyway thanks for the instructions, made it pretty easy.
Also once I got the setup back the way I use it some of the icons have been updated but not found any major problems so far.
out of interest whats the easiest way of backing up the config to save having to reset it all ?
Old 04-02-2009, 3:09 PM   #10
1,926, Level: 10
Points: 1,926, Level: 10 Points: 1,926, Level: 10 Points: 1,926, Level: 10
Has anyone tried this upgrade on a T-Mobile UK branded omnia?
I would be interesed to hear how it went.
Tony
Old 04-02-2009, 5:12 PM   #11
4,428, Level: 15
From what i know, the only way it would affect a Vodafone contract, is: they would not repair it for you, you would prob have to send it to Samsung, but check first, i know several people have lost faith in VF's ROM's and converted to others, imacken, for one, if VF find out that you are not running a VF ROM, don't think they can do anything else,
hope this helps
Old 05-02-2009, 4:06 PM   #12
1,926, Level: 10
So has no one done this upgrade on a T-Mobile Omnia (UK or otherwise)?
I am eager to try but would like to hear about any problems before I brick the phone.
Tony
Old 05-02-2009, 8:34 PM   #13
6,061, Level: 18
Tony
I cant see you hitting any problem no matter which provider you use, once upgraded its unbranded.
Old 06-02-2009, 12:39 PM   #14
1,926, Level: 10
The two main reasons (apart from performance) I am looking to do this is
1) Active Sync will work with two computers.
2) Divx works with more divx files
Number 1 is my most important.
Has anyone confirmed that this update will correct this problem?
Also is there a way to backup the current image incase I want to back out the update?
Old 07-02-2009, 10:51 AM   #15
3,308, Level: 13
Points: 3,308, Level: 13 Points: 3,308, Level: 13 Points: 3,308, Level: 13
Thanks: Gave 23, Got 25
Id also be interested to know if anyone has tried this on T-mobile
Old 07-02-2009, 8:12 PM   #16
1,876, Level: 10
Points: 1,876, Level: 10 Points: 1,876, Level: 10 Points: 1,876, Level: 10
Hi guys.
I have an Orange branded Omnia, and want to get rid of their crap.
I've tried to follow the instructions posted but I don't have a 'values' folder in the control panel so becomea bit stuck.
Can anyone suggest what i can do?
thanks
Paul
Old 11-02-2009, 11:00 PM   #17
MarkR's Avatar
9,312, Level: 23
Step 1: Click on this link to download the PHM Registry Editor PHM.lu Download Center and then click on 'Download PHM Registry Editor : Pocket PC Edition'
You need to change the values and the only way to achieve this is to follow the instructions above. You can tell what version you have by going to Start - Settings - System and then Version. Let me know how you get on.
Old 24-02-2009, 2:52 PM   #18
1,582, Level: 9
Points: 1,582, Level: 9 Points: 1,582, Level: 9 Points: 1,582, Level: 9
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Higuys you all seem to know your stuff, could anyone help em with my problem (I posted a thread today) im really stuck and have no phone! my version is MSHG1 not sure if this has anythign to do with the problem
Old 27-02-2009, 9:36 PM   #19
cga cga is offline
1,893, Level: 10
Points: 1,893, Level: 10 Points: 1,893, Level: 10 Points: 1,893, Level: 10
Thanks: Gave 1, Got 0
Cool Samsung Omnia i900 Firmware. Wap and MMS
I have updated from Orange firmware update for BVHH1 to MSHJ1.
Everything is fine, the only thing is that I can’t get WAP and MMS configurations to work.
Vodafone sent me the configuration by a text message and it didn’t work. I got the message, enter password, the I got a message saying your configuration has been changed, but actually it didn’t do anything to the configuration, still I don’t have access to the internet through Vodafone live. Also I have tried the WAP and MMS configuration from Samsung website by a message as well and it didn’t work, the same that happened with Vodafone message.
Vodafone sent me an email with settings below to do it manually but I don’t find the way around.
Live! settings:
These settings should be in place by default.
To set them manually:
Go to Start>Settings>All settings >Connections>GPRS.
New>Live
Connects to: work
Access point: live.vodafone.com
Username: dublin
Password: dublin
Authentication type: none
Internet Settings:
New>Misp
Connects to: The Internet
Access point: isp.vodafone.ie
Username: vodafone
Password: vodafone
MMS GPRS Settings.
Go to Start>Settings>All settings>Connections>GPRS.
New>MMS.
Connects to: MMS network
Access point: mms.vodafone.net
Username: dublin
Password: dublin
Can some one help me to set up my WAP and MMS for Vodafone Ireland
cheers
Old 18-03-2009, 10:27 PM   #20
1,807, Level: 9
Points: 1,807, Level: 9 Points: 1,807, Level: 9 Points: 1,807, Level: 9
I have now upgraded my firmware to MSHJ1 on orange. Process was really straight forward. I used CeRegistry Editor, which runs from host PC. The best thing about the firmware upgrade is that it gets rid of the orange skin. And I have to say this alone makes the look and feel of the phone much better.
Old 20-03-2009, 4:49 PM   #21
5,850, Level: 18
Points: 5,850, Level: 18 Points: 5,850, Level: 18 Points: 5,850, Level: 18
Mine does not read this in the registry, BVHH1_HH1 it just reads BVHH1 do I have to put in all of this MSHH1_HH1 or just change it to MSHH1
Old 20-03-2009, 11:20 PM   #22
5,850, Level: 18
Went for it anyway using the above method and worked a treat.
mitchj9 (19-09-2009)
Old 22-03-2009, 10:10 AM   #23
1,926, Level: 10
I upgraded my T-Mobile (UK) branded Omnia yesterday and it worked fine.
I will report back in a few days about my experiences but for now it seems all good.
Currently upgrading my sons omnia.
Note: information on both the "Storage card" and "My Storage" was NOT deleted during the upgrade - but I would suggest, as with any upgrades, do a backup first.
Hope this helps
Tony
Old 31-03-2009, 12:02 AM   #24
1,783, Level: 9
Points: 1,783, Level: 9 Points: 1,783, Level: 9 Points: 1,783, Level: 9
Hello
My custom version is BVHH1_HJ2.If i were to change it to MSHH1_HH1, will it affect the system?
thanks!
Old 21-05-2009, 12:47 AM   #25
2,066, Level: 10
Points: 2,066, Level: 10 Points: 2,066, Level: 10 Points: 2,066, Level: 10
I made the firmare update as indicated with one glitch. At the beginning, the update is making a reset and at the restart ActiveSync didn't start. I was waiting for 20 minutes and nothing happened. Then I made a hard reset which didn't reset but actually started the update.
However, I do have a big problem now. In order to make the phone working (and the network I think), it asks me for a PIN. What kind of PIN please? It doesn't seem to be the SIM card PIN. How many digits? I already tried few numbers without success and I'm afraid I'll lock the phone. This phone was carried by Orange in the UK.
If you guys already did this update, you should have had the same situation. Please, advice me! Many thanks! Liviu
Old 21-05-2009, 1:21 PM   #26
1,926, Level: 10
My pin was the pin number from my security on the sim and was 4 digits.
What is the title of the screen you get...?
Tony
Old 21-05-2009, 1:42 PM   #27
2,066, Level: 10
On top bar is written Phone on left and on the right some icons starting with Net having a lock on it.
The some white space where is written:
Enter PIN
Only emergency calls can be made without a PIN
Then, on the bottom side, is a keyboard phone like style allowing only numbers to be entered.
I don't understand why would the phone ask for a SIM card PIN after the upgrade. I already used different SIM cards from different countries before the upgrade and it didn't ask me for a PIN.
In the mean time I'm starting to believe that it asks me for a PIN because the SIM card is from Canada and the upgrade I did was for UK. I did it for UK because originally the phone was sold in the UK.
Thanks,
Liviu
Old 21-05-2009, 3:47 PM   #28
1,926, Level: 10
You may be correct, but the pincode seems to be the pin code from the sim. Also before when you first used the sim you may have entered the delivered sim code and then set phone to not ask for it, - which was a phone setting and was erased when you did the upgrade.
... guessing...
If its not a pin code you put in, then your phone carrier can give you the pin code, or the puk code if you manage to lock the phone.
Some vendors use the last 4 digits of the number printed on the back of the sim card as the pin code... ask orange do they do this.
Good luck
Old 24-05-2009, 9:57 PM   #29
1,680, Level: 9
Points: 1,680, Level: 9 Points: 1,680, Level: 9 Points: 1,680, Level: 9
I guess this question is more for you TonyOCL, i got a Tmobile branded i-900 with firmware BOHH5 and would like to upgrade to the latest firmware build but wanted to see if someone did this succesfully 1st.
Which firmware version are you currently running on your fone and how did you go about it ? Did you just modify the version string in the registry prior to updating with the firmware ?
thanks
Old 25-05-2009, 3:45 PM   #30
1,926, Level: 10
[QUOTE=camid004;9578772]Hi,
I have done it on my phone and 2 of my sons phones successfully... like the upgrade but hoped it fixed two things in addition to what it did correct.
The outstanding things for me are
1) Divx - not all formats supporte (but I downloade the divx player for phones that don't have divx built in and it works better - not perfect)
2) the active sync problem with 2 pc's - if you haven't noticed the problem then you don't need it. If you do have the problem it will exist when you upgrade.
Apart from that the kids like the real MSN client that comes back with the upgrade and the hosts of other bits and pieces.
It is faster too ---- well I think so anyway.
I am now at MSHJ1.
All I need is the last boy to let me upgrade his phone but he won't accept loosing his sms messages :-)
"Did you just modify the version string in the registry prior to updating with the firmware ?" - YES
Good luck and let me know if when you do the upgrade it gives a higher version that I got. I did my upgrade at the beginning of March.
Bye
Powered by
 Latest popular product prices
Samsung E1080
2 prices from
 £14.49 Click to show/hide the offers
Samsung Ch@t 335
1 price
 £64.49 Click to show/hide the offers
Samsung Ch@t 222
1 price
 £63.12 Click to show/hide the offers
Samsung GT-S5610
1 price
 £89.99 Click to show/hide the offers
Samsung Galaxy Mini GT-S5570
2 prices from
 £149.36 Click to show/hide the offers
Samsung B2710
1 price
 £99.99 Click to show/hide the offers
Samsung Galaxy Y S5360
2 prices from
 £110.88 Click to show/hide the offers
Samsung Galaxy Y Pro B5510
2 prices from
 £134.62 Click to show/hide the offers
 Updated February 11th at 4:30pm. Prices include delivery.
