| Re: Using Samsung mobile with pacemaker - help
Hi Rob,
I've checked all the stuff that came with his phone and the only thing it refers to is Specific Absorption Rate or SAR. We don't know if that refers to the electrical output or the signal transmitted to the receivers & back when the phone is in use. Perhaps someone can tell us.
The SAR limit on his phone is 2.0w/kg which looks like a wattage figure but not sure why it relates to kg which I guess is kilogram.
If this is the output then we're ok as the limit for use with a pacemaker is 3w. Otherwise you are advised to use a headset so that the phone is at a distance from his body.
