| Re: debrand m8800 pixon and now wont turn on
I would bet that somewhere in the firmware update instructions there will be a warning along the lines of 'you are doing the upgrade at your own risk', ie if you kill the phone then it is your own fault. They would just say that there is nothing wrong with the firmware, but you may have done something wrong to cause the update to fail, ie unplugged it during the process of updating.
Taking the phone to an official repair centre may mean they can replace the firmware, but almost certainly at a cost.
Mark.
