AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration
LinkBack Thread Tools Display Modes
Old 15-10-2003, 4:53 PM   #16 (permalink)
kwangomango's Avatar
Thanks: Gave 1, Got 0
Originally posted by Badger
On my Aconda/Pio 565 pairing (and your setup too it appears)
No mine is fine. I think i introduced some unecessary confusion. There are two versions of the THX calibration. Some of them have 8 squares and some of them have just one. Is your Lion King one called Optimode or Optimser? I believe Optimser is the newer one which has 8 squares(like my PAL T2) and Optimode is the older one with one square(like my NTSC Toy Story). I think!?
kwangomango is offline
Old 15-10-2003, 6:19 PM   #17 (permalink)
OK the Optimode/Optimiser thing makes sense
For my piece of mind have you got/tried any of the NTSC THX optimiser tests as you only mention the T2 one
Phil
Badger is offline
Old 15-10-2003, 7:34 PM   #18 (permalink)
fatbob's Avatar
I've just put the optimode on the R1 Lion King disc and on my PC there are 8 clearly visible blocks (4 different shades) - The text also states "This test displays four distinct shades of white in eight boxes"
On my Aconda/Pio 565 pairing (and your setup too it appears) you just see 1 white block - which isn't right
It does appear to be only a problem with NTSC though (I wonder if it's to do with the internal Progressive Scan processing ?)
Phil
I've read some postings on this forum that the Loewe Aconda suffers from a white crush problem on it's RGB and component outputs. That would explain why the Optimode test for contrast is displayed as a single white box rather than several small boxes of differing shades.
One way to be sure is to try the same test using S-video, as the white crush problem only affects RGB and component.
Cheers.
fatbob is offline
Old 15-10-2003, 10:11 PM   #19 (permalink)
I'm currently using the S-Video (via Scart) output - S-Video directly into the front port is exactly the same, so i'm not totally convinced
Phil
Badger is offline
Old 15-10-2003, 10:17 PM   #20 (permalink)
Gordon @ Convergent AV's Avatar
Thanks: Gave 472, Got 972
As I said previously. It's probably a combination of DVD player output voltage and TV input sensitivity
Gordon
Work: http://convergent-av.co.uk/about.html
My Photos: Flickr
My Blog:Do I know you?
Gordon @ Convergent AV is online now
Old 15-10-2003, 10:25 PM   #21 (permalink)
Phil
Sorry mate, only Optimiser disc i've got is the PAL T2(and that displays the 8 squares correctly). I've got NTSC Finding Nemo due within the next couple of weeks and i believe that has the THX Optimiser. Will check it out for you when i receive it.
calibration, visual
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
