AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration
LinkBack Thread Tools Display Modes
Old 29-01-2007, 5:33 PM   #1 (permalink)
TV Calibration
Hi everyone, I am new to this forum and had a question...I recently purchased a Panasonic Plasma TH-42PX6U and Panasonic LCD Projection PT-52LCX66. I have been reading about TV Calibrations and have tried to find the best way to calibrate them but not spending a high dollar amount. I haven't even talken the TV's out of the box yet as I am waiting to move into my new place. I saw at Costco the DataColor SpyderTV and have been trying to find information on it. Is it worth it for the calibration or not I am not too familiar with what products are out there for calibration, of course I will not get a picture that maybe a professional would get me but seems like an easy tool to use and maybe could make a difference
alpineflip is offline
Old 29-01-2007, 5:54 PM   #2 (permalink)
Thanks: Gave 19, Got 13
Smile Re: TV Calibration
There are three options:
You could use DVE (SD or HD versions available about £10)
http://www.woolworths.co.uk/ww_p2/pr...l?pid=50760330
You could try the SpyderTV which I have not used but I have heard good things about
Or you could pay to have it ISF calibrated (mine cost £300)
But you should run it in on low brightness & contrast settings for about 300 hours before the ISF
Hope this helps.
bolts is offline
Old 01-02-2007, 9:44 AM   #3 (permalink)
Re: TV Calibration
I think thats a joke as the release date is 1 January 2020
digijim is offline
Old 01-02-2007, 3:02 PM   #4 (permalink)
merifon's Avatar
Thanks: Gave 0, Got 17
Re: TV Calibration
you could even try this free option: download from here a home brew testDVD:
www.merifon.3000.it
enter and in upper right corner there are links to files and docs
Then, if You wish, a comment will be appreciated
saluti M
merifon is offline
Old 12-02-2007, 11:20 PM   #5 (permalink)
Thanks: Gave 7, Got 10
Re: TV Calibration
Superb link Merifon, Im always messing about with the settings on my toshiba CRT television and Im never happy with the results, hopefully this should help me bigtime. Currently downloading as I type this
truscotsman72 is offline
Old 05-03-2007, 1:29 PM   #6 (permalink)
Thanks: Gave 1, Got 0
Re: TV Calibration
Merifon, is the site down at the moment, was rather interested in this but can't get it at the moment.
Valve
valve90210 is offline
Old 06-03-2007, 10:28 PM   #7 (permalink)
merifon's Avatar
Re: TV Calibration
yes, the redirection seems not working at the moment...
try the complete link, it should work
http://digilander.iol.it/merifon/
saluti M
merifon is offline
calibration
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
