23-01-2007, 11:15 AM
#1 (permalink)
Thanks: Gave 15, Got 50
do i fill a air gap.im not sure
please help.im building my own home cinema and one wall in the room is next to the neighbours (its also on the second floor of my house if that helps) the walls are very thin (ie i can hear them put plugs on and off) ive got sum good speakers that give out powerful bass and ive had to move my dj gear to a different room already.the neighbour was not happy as there light fittings used to vibrate.anyway im putting three suade panels on the wall. with a 6 inch gap between each one so not all the wall will be covered.
the panels are 87 cm wide and run the hight or the room.
ive put a baton down the side of each panel so i can run cables behind them the gap from the wall is quater a inch,then its plywood,then quater inch foam,then
a layer of polyester covered over with suade.
will i get any gain in filling the gap between the wall and plywood.
ie does the air gap help.
im not sure what else to do.its a big problem for me coz the house is rented and i have not evan got a sub yet.
ps i cant go any more into the room as my screen drops from the ceiling.
big thanks to anyone who takes the time to help.
TABLE MANNERS,B&Wdm604s3, lcr600,ds7 OWL moto screen INFOCUSIN81 RAKOlights,van den hul.qed,CHORD epic spk cable.optimum SONY,rcdw100,vtxd800 ARCAM FMJ AV9,P7.Dj stuff. TECHNICS sldz1200x2 cd decks & shex1200 mixer.mdrv700 Kdl46w2000.B&WLM1 spk inc kef powered sub.
23-01-2007, 12:38 PM
#2 (permalink)
Thanks: Gave 17, Got 55
Re: do i fill a air gap.im not sure
To isolate the sound you must not screw anything to the party wall, all the batons must not touch the wall and must be fixed to the floor ceiling and side walls Put foam underlay strips between baton and side wall/ceiling , fill the gap with fiberglass or rock wool and if possible two layers of plasterboard over the batons , even one screw or nail in the party wall will transmit the sound, think of a needle on an old gramophone, its the same effect.
23-01-2007, 2:51 PM
#3 (permalink)
thanks for the advice.ive used 1 plastic wall clip for each panel in the center and it seams to hold fine but i have not put the foam on the ply yet.i was finking of useing 2 inch velcro strips down the panels do u fink that wud carry vibrations. the panels weight also sits on the skirting because ive got trunking going round the room which will sit flush with the suade panel.
23-01-2007, 3:15 PM
#4 (permalink)
Thanks: Gave 110, Got 108
hold on,
the panels your putting on the wall are suede panels, that are the height of the room, and mounted to the wall , with an air gap behind the panel andwith gaps between them? if thats the case there is NO soundproofing benefit.
the airgap, in this case, will make difference.
23-01-2007, 4:38 PM
#5 (permalink)
was just cin if it wud help.i no sound proofing is not the same sound absorption. ive looked it up for sum time just wonderd if i wud gain any sound proofing benefits for the neighbours.
23-01-2007, 6:58 PM
#6 (permalink)
The advice I gave was to reduce noise transference to and from your neighbors property, I have built a wall and ceiling this way using plans supplied from a specialist company, they recommend a filling of fiberglass or rock wool this is not for sound deadening in your room, the secret is to isolate the partition wall from your room like a sort of "floating wall" make sure the plasterboard does not touch at the edges at the wall and floor/ceiling, and fill the gap with mastic. and do not tighten the batterns hard they should float, I wish i could find the plans or I would send you a scan,
24-01-2007, 7:57 AM
#7 (permalink)
and your advice was good for noise transmission, the OP is about panels on the wall though, not soundproofing
26-01-2007, 9:34 AM
#8 (permalink)
ok,i will have a air gap then,i have taken on board what you said about soundproofing for when i get my own place,when this happens i will go the whole hog.cheers guys
