AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration
LinkBack Thread Tools Display Modes
Old 16-01-2007, 2:30 PM   #1 (permalink)
Epoman's Avatar
Thanks: Gave 129, Got 47
Sound deadening material for noisy Xbox
I've got a pretty noisy Xbox that you can hear whizzing from the other room.
Just wondered whether placing it on some sort of sound deadening material might make it quieter? if so, any idea what I should be looking to buy?
ta
Display's: Infocus IN76 PJ & Owl 8' tab tensioned screen, Pioneer 508XD, Pioneer 434HDE, Pioneer 433MXE | Sources: PS3 & Denon DVD3800| Processor: Arcam AVP700| Power: Arcam P1000 | Speakers: M&K SW85's x6 | Sub: B&W ASW750
Epoman is offline
Old 16-01-2007, 3:23 PM   #2 (permalink)
Thanks: Gave 110, Got 108
Re: Sound deadening material for noisy Xbox
be wary of smothering it, it will overheat. We sometimes provide melamine foam pads for plasmas, so perhaps something like that might take some of the whine away...
mattym is offline
Epoman (16-01-2007)
Old 16-01-2007, 3:40 PM   #3 (permalink)
Epoman's Avatar
Thanks. I was looking for something to go under the Xbox. I'll have a look at the pads.
ta
Epoman is offline
Old 19-01-2007, 6:18 PM   #4 (permalink)
does the fan noise lesson if you push down on the top of the xbox?
mattym is offline
Old 19-01-2007, 10:42 PM   #5 (permalink)
Epoman's Avatar
I'll have a go and report back.
Epoman is offline
Old 19-01-2007, 10:54 PM   #6 (permalink)
johnscarlet's Avatar
Thanks: Gave 87, Got 303
Assuming you are talking Xbox1 and not 360 , there are some tutorials over at xbox-scene for quietening an xbox . Most of them involve opening it up though , if you have'nt already
John
My opinions expressed here do not represent those of the AV Forums or it's associated websites
The posting of vast slabs of text from news sites and other freely available sources is not acceptable,especially when copyright may be an issue, please provide a link.
johnscarlet is online now
Old 22-01-2007, 9:46 AM   #7 (permalink)
Epoman's Avatar
No difference whatsoever.
John
Sorry I didn't make myself clear, it's an Xbox360. It's still under warranty so i would not want to open it at this stage.
Epoman is offline
Old 22-01-2007, 3:45 PM   #8 (permalink)
if pushing down doesnt quiet it then floating it wont make any difference...
mattym is offline
Epoman (22-01-2007)
Old 22-01-2007, 7:36 PM   #9 (permalink)
Epoman's Avatar
Thanks for the reply. So I've just got to live with the noise. Not fair really as my first Xbox was virtually silent but, without exaggeration, this replacement can be heard from the next room. Performs faultlessly though so maybe I shouldn't complain.
Epoman is offline
Old 25-01-2007, 7:54 PM   #10 (permalink)
Thanks: Gave 51, Got 9
The noisiest thing on the xbox 360 is the dvd drive, the fans are not nearly as loud. Some versions are louder than others & the later models use a different quieter drive. This link shows you how to identify which drive you have:
http://www.bxbox360.com/news/what-br...60s-dvd-drive/
aventhusiast is offline
Epoman (26-01-2007)
Old 26-01-2007, 10:24 AM   #11 (permalink)
Epoman's Avatar
Thanks, I'll have a look at it tonight.
Epoman is offline
deadening, material, noisy, sound, xbox
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
