AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration
LinkBack Thread Tools Display Modes
Old 08-01-2007, 5:57 PM   #1 (permalink)
Daddy k's Avatar
Thanks: Gave 312, Got 250
Calibrating TV for sky digi
this may be a silly question but whats a good way to calibrate my tv for sky?
obviously if i use dve im calibrating my component input,
my sky is using rgb scart.
any ideas?
Harman Kardon AVR230 Amp. BK Monolith DF subwoofer. B&W VM1 speakers x5.
Samsung Q96 50" HD plasma running Sky HD @ 1080i
Harman Kardon DVD 22. Sky+ Multiroom. XBox 360 add me on LIVE:krismc1.
See my setup in members gallery:"dads new pad"
Daddy k is offline
Old 08-01-2007, 7:05 PM   #2 (permalink)
Assured Advertiser
Piers's Avatar
Thanks: Gave 24, Got 145
Re: Calibrating TV for sky digi
Your Harman Kardon DVD22 looks to have an RGB scart socket so why not use this to feed the DVE signal to the input on the plasma that your Sky+ is hooked up to. This should get your settings for brightness, contrast, colour saturation etc. close to optimum. I then tend to use actual real video material from the Sky+ to iron out the differences between the ideals of DVE and what the Sky box is actually delivering.
Piers (Home Cinema Engineering Ltd.)
ISF and HAA calibration <-- Click for details
Train to be an ISF or HAA Calibrator <-- Click for details
Piers is online now
Daddy k (09-01-2007)
Old 09-01-2007, 10:34 AM   #3 (permalink)
Daddy k's Avatar
cheers matey,
i suppose i can then re run dve and do the adjustments on the dvd player to get the dvd player to match once iv then adjusted slightly for my sky.
Daddy k is offline
Old 10-01-2007, 1:05 PM   #4 (permalink)
Assured Advertiser
Piers's Avatar
Your plasma surely has separate setting memories for component and RGB scart inputs? Cailbrate the scart input with a temporary scart connection from the DVD player. Reconnect Sky to the scart input and tweak your settings. Connect the DVD player to the component input and calibrate again for this input.
Piers is online now
Old 11-01-2007, 11:54 AM   #5 (permalink)
Daddy k's Avatar
doh yeah lol, well ill calibrate the 360 using dve (component) then tweak the settings using the dvd players settings with dve being run on that via component (for dvd watching) then connect dvd player up to my rgb scart and adjust tv for that!
Daddy k is offline
calibrating, digi, sky
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
