AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration
LinkBack Thread Tools Display Modes
Old 07-01-2007, 4:11 PM   #1 (permalink)
Thanks: Gave 22, Got 10
Auralex Sheetblock
Been looking into this product it seems to be the stuff to have.
My situation is that i am building an extension starting march this year. One of the rooms 5m x 2.75m will be used as my HC come sitting room. I want to soundproof it as much as possible as the main bedroom will be above it.
Going on my room size how many rolls do you reckon i would need ?
Or do you have any other ideas ?
Stephen
http://www.dolphinmusic.co.uk/page/s...roduct_id/2805
stephen_ is offline
Old 07-01-2007, 4:34 PM   #2 (permalink)
Thanks: Gave 110, Got 108
Re: Auralex Sheetblock
sheetblock is another form of MLV, not the most efficient product you can use, its heavy and its expensive, 120sqft roll costs 4 times as much as 192sqft of Green Glue, there are cheaper MLV on the market though
how many rooms in total are you looking to treat or just the one?
mattym is offline
stephen_ (07-01-2007)
Old 07-01-2007, 6:33 PM   #3 (permalink)
I am looking to treat just the one room with this product.
One of the bedrooms (teenage daughter) will be sealed with some kind of acoustic sealant to stop any noise spillage along with heavy underlay & heavy carpet.
What do you recommend on the MLV route ??
I was hoping to use green glue as well, doubling up on plasterboard with rockwool.
stephen_ is offline
Old 07-01-2007, 6:46 PM   #4 (permalink)
Thanks: Gave 8, Got 31
Stephen,
Take a look at Custom Audio Designs site, it has loads of good information about sound proofing. http://www.customaudiodesigns.co.uk/help.htm
Denon A1SR, Pioneer 50MXE1, Lumagen ProHDP, Arcam 79, Pioneer LD 919E, (2) Sky+, Sony 777ES Tuner, Pioneer 509 CDR, JVC DVHS, SVHS, (2) Xbox 360 + HD DVD , Xbox, PS2, StraightWire & VDH cables, Crestron Pro 2, STX-1700c, ST-LT Lutron Interface, AppleTV, MS Home Server, Kef THX 7.2, Zektor HDS4.2
pemberto is offline
Old 07-01-2007, 11:16 PM   #5 (permalink)
I would save money and go with doubling up the green glue and plasterboard(with rockwool in the walls), its well tested, works well. Seal the room your treating and it should be fine, if your building new studs then flanking noise will be reduced to a minimum.
Quantities, well a Sheet of plasterboard 8'x4' takes 2 tubes of Green, so you can work out your board and green content from that
www.greengluecompany.com for much information on greenglue and its use.
mattym is offline
Old 23-07-2008, 4:31 PM   #6 (permalink)
If it were my room I'd install a floating ceiling with high density acoustic mineral wool between the joists then mount resilient bars. Finally I'd attach a double layer of acoustic plasterboard with sound barrier mats sandwiched between them.
This solution works, it adds mass and decouples the ceiling and the new ceiling and does NOT rely on any snake oil or magic beans.
If you have stud walling you will also need to treat flanking sound by treating the walls. Again use acoustic mineral wool between the studs then resilient bars with a layer of sound barrier mat sandwiched between acoustic plasterboard.
With all these measures more mass and decoupling will mean more noise reduction. Boring and simple, but true.
Hope this helps.
A Sound Basis is offline
Old 02-08-2008, 9:14 AM   #7 (permalink)
Gary Lightfoot's Avatar
Thanks: Gave 5, Got 305
I wouldn't use resilient bar if you want to use the room for audio playback rather than to just soundproof it. RB can turn a surface into a diaphragmic absorber and reduce the rooms bass with very little chance of getting it back (unless you remove the RB). It's good for soundproofing but an unknown for how it would effect the room for audio playback.
Gary
My Old Home Theater
Basic Projector Calibration
Gary Lightfoot is offline
auralex, sheetblock
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
