AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration
LinkBack Thread Tools Display Modes
Old 04-01-2007, 8:09 PM   #1 (permalink)
Stel's Avatar
Thanks: Gave 0, Got 32
Acoustic/Thermal insulation
hi all, little help needed here, like most am converting detatched garage to HC,what type of insulation do i go for that has very good thermal and acoustic properties,such a wide market i am lost in, i looked at custom audio website but they seem to be more acoustic than thermal.HHHHEEEEEELLLLLPPPPPP
Stel is offline
Old 04-01-2007, 9:17 PM   #2 (permalink)
Thanks: Gave 8, Got 31
Re: Acoustic/Thermal insulation
Stel,
Have a look at the threads in this section, plenty of information available.
Also check out Custom Audio Designs website, its full of information on all the different aspects of sound proofing.
http://www.customaudiodesigns.co.uk/help.htm
Hope that helps,
Pemberto
Denon A1SR, Pioneer 50MXE1, Lumagen ProHDP, Arcam 79, Pioneer LD 919E, (2) Sky+, Sony 777ES Tuner, Pioneer 509 CDR, JVC DVHS, SVHS, (2) Xbox 360 + HD DVD , Xbox, PS2, StraightWire & VDH cables, Crestron Pro 2, STX-1700c, ST-LT Lutron Interface, AppleTV, MS Home Server, Kef THX 7.2, Zektor HDS4.2
pemberto is offline
Old 04-01-2007, 9:22 PM   #3 (permalink)
Stel's Avatar
Originally Posted by pemberto View Post
Stel,
Hope that helps,
Pemberto
thanks, lookec at custom audio,still confused,i am thinking of rockwool flexi slabs,any1 know these or indeed used em.
Stel is offline
Old 04-01-2007, 9:36 PM   #4 (permalink)
Using Rockwool will be fine and will give you good thermal insulation as well as soundproofing. From what I remember they are available in different thichnesses.
Once completed you can also use rockwool to make sound absorbing panels in your HT. Have you looked at the Rockwool website, loads of information.
Hope that helps,
Pemberto
pemberto is offline
acoustic or thermal, insulation
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
