AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration
LinkBack Thread Tools Display Modes
Old 01-01-2007, 6:01 PM   #1 (permalink)
Room setup
I need some advice on speaker placement.
I'm planning on getting some small form speakers (e.g. Mission M-cube) and as it's a smallish room I had planned on positioning these as per attached image.
The four corner speakers would be placed below the ceiling (just under 7 foot) and the center speaker on the tv cabinet.
Will this sound ok with the speakers high up on the walls?
Thanks.
Phoolish is offline
Old 01-01-2007, 8:31 PM   #2 (permalink)
Thanks: Gave 110, Got 108
Re: Room setup
not ideal, you want the speakers to be evenly spaced if possible, the front ones and your listening position should be a triangle.
there is an excellent link to dolby or thx somewhere on here that gives excellent advice..
mattym is offline
Old 02-01-2007, 10:24 PM   #3 (permalink)
Re: Room setup
Found the Dolby diagram here:
[url="http://www.dolby.com/consumer/home_entertainment/roomlayout.html"]
I think I'll move the centre speaker, and have the others tilted towards the main seating area.
Thanks.
Phoolish is offline
room, setup
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
