AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration
LinkBack Thread Tools Display Modes
Old 15-12-2006, 8:31 PM   #1 (permalink)
Thanks: Gave 5, Got 1
Some 6.1 speaker placement pics for you to look at
Anyone got any comments on the attached pics (no laughing), the red boxes show where I plan to put the rest of the speaker. The oval is meant to be my head lol
Centre front : On bracket attached to wall to stop little people playing with it, distance from wall to front of LCD is 8 inches.
Centre rear : Behing seated position. Distance from wall to ears is 18inches though.
Surround rears : Mounted on side walls on Maplins adjustable stands, pointing towards listener aprox 100-120 degrees.
Just got a few q's though:
1) Should there be a clear 'line of sight' between ears and surround rears? Obviously the sofa headrest could block this potentially.
2) Is centre rear going to sound ok right behind my head, or should it be to one side slightly (or even omitted)?
Thanks for reading!!!
alphasmith is offline
Old 16-12-2006, 12:25 AM   #2 (permalink)
thekingbeyond's Avatar
Thanks: Gave 9, Got 60
Re: Some 6.1 speaker placement pics for you to look at
I would say the rear speakers are to low and need to be at least 1 mtr or higher above ear hight, they will sound very localised at the height you want to put them.
Samsung SP50L7H dlp, Sanyo PLV-Z3, htpc,Denon kAVC-A1SE,sky+, Kef ref L&R, XQ2C centre,tdm34ds side, xq1 rears. tdm45b sub, Bedroom-Pioneer PDP-433MXE Plasma, Denon dvd-1920 player
dvds for sale
thekingbeyond is offline
alphasmith (16-12-2006)
Old 16-12-2006, 11:27 AM   #3 (permalink)
Thanks will take your advice, but should the rears be pointing towards the listeners ears or mounted flat on the side wall (i.e. pointing at each-other)?
Also should the centre rear be angled down towards the listener also?
Thanks for your patience
Old 16-12-2006, 11:47 AM   #4 (permalink)
I would have the rear sides point at each other, and experiment with directing the speakers towards the listner and pointing them away to see what works in your room for you.
I would recomend some bipole speakers for the sides.
dvds for sale
Old 16-12-2006, 1:09 PM   #5 (permalink)
Would love to get some bipoles but am on a budget at the moment, just got the cheap and cheerful Sony SSP88 6.1 package from Richer Sounds until I can afford the ones I want.
I was going to mount the left and right rears on Maplins brackets (see photos) which are fully adjustable, and mount the centre rear on a fixed right angle bracket.
Can you see any problems with this, or would it be acoustically better to mount the rear left & right direct onto the wall? (speakers have a built in hook eyelet)
Pics attached, as they say they paint a thousand words.
Thanks again for your continued advice
Old 18-12-2006, 2:35 PM   #6 (permalink)
I think mounting the the speakers on brackets will help isolate the speakers from the wall, and will sound better than using the eyelets
dvds for sale
alphasmith (18-12-2006)
Old 18-12-2006, 4:40 PM   #7 (permalink)
thekingbeyond can't thank you enough for all your advice - now all I have to do is get installing
Old 19-12-2006, 1:11 PM   #8 (permalink)
Thanks: Gave 57, Got 73
alphasmith i'm hopeing you can help me. I have the same speakers as yourself but i'm struggleing to find the correct brackets for the wall. Can you tell me where you got your brackets from?
Thanks,
Smaz.
You couldn't fool your mother on the foolingest day of your life with an electrified fooling machine!
Sony Bravia KDL32S2010, Sony STR-DA1200ES, Sony SSP88's, LG DR198H DVD HDMI Upscaler, Sky HD, Xbox 360, Xbox HD-DVD Drive, Wii
The Smaz is offline
Old 19-12-2006, 1:34 PM   #9 (permalink)
Woodywizz's Avatar
Thanks: Gave 827, Got 931
Thanks,
Smaz.
Looking at the pictures posted earlier, it seems that the op got them from here.
Matt
Panasonic TH42PX70; Onkyo TX-SR606; Mordaunt Short Genies 6.1; SkyHD; PS3 60GB;
PSN: Woodywizz; The Official AVF FIFA League: The Championship - Team: Bordeaux ;
Favourite Serial Killer :
Charlie Manson and The Family
Woodywizz is online now
Old 19-12-2006, 4:17 PM   #10 (permalink)
Yeah i noticed that but i'm a little sceptical about buying stuff from that region of the world. I was really hoping that there would be a UK reseller.
Oh well..
Smaz.
The Smaz is offline
Old 19-12-2006, 4:27 PM   #11 (permalink)
Oh well..
Smaz.
I think he got them from maplins, see post 5
dvds for sale
Old 20-12-2006, 8:41 AM   #12 (permalink)
You are correct - Maplins order code L98AB priced £7.99 per pair, hope you still have enough time to get them for X-mas Smaz
PS- Fitted most of the speakers now, will post some pics when all done
The Smaz (20-12-2006)
Old 24-12-2006, 5:11 PM   #13 (permalink)
Thanks: Gave 0, Got 2
Alphasmith, im looking at getting these Sony SSP88 speakers, can you tell me what connect the sub has, does in connect to your amp via an phono type plug or is it just a bradded wire connection
lettuce is offline
Old 25-12-2006, 8:34 PM   #14 (permalink)
Hi lettuce, the sub connects via phono plug.
Old 26-12-2006, 11:33 AM   #15 (permalink)
Thanks for the reply, do you get a phono lead with the sub??
lettuce is offline
pics, placement, speaker
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
