Re: BFD or passive room treatment
I have a BFD and it works better than I expected, when used with Room EQ Wizard and a Radioshack SPL meter its pretty simple to do.
The fact you have lost the deepest bass could be a problem though unless you have a sub with a lot of headroom you don't use, because trying to push up the gain on low frequencies could cause clipping of the sub or distortion.
Putting the sub in or near a corner is a good way to boost the lowest frequencies but it sounds like you've run out of places to put it.
If there's anywhere left to try placing the sub, that is definatly the best start but I would still recomend a BFD to flatten everything out.
The other problem might be the relationship between the main speakers and sub because your peak is likely to be in the crossover. Try playing with the phase on the sub to see if this improves things.
Hope this helps in some way.
Andrew
Edit: You say the sound quality has reduced? I assume you mean improved?
My Home Cinema - Optoma HD70, Denon AVR-3805, Monitor Audio Bronze B4 x2, B centre, BFX x4, SVS PB10, BFD, Sky HD, Denon DVD-1910, Senn HD 485, Nintendo DS, PSP, Wii.
Near Silent PC - Intel C2D E6700 (OC to 3.4Ghz), 2Gig RAM, 8800 GTS 640 OC, Vista.
Car - BMW E36 318iS coupe (M44)
