AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration
LinkBack Thread Tools Display Modes
Old 17-11-2006, 9:26 AM   #1 (permalink)
miceri's Avatar
Thanks: Gave 45, Got 62
DVE On Multiple Inputs
My 507 is approaching the 200hrs ish mark. Decided that I would try using my DVE to fine tune a little.
My inputs are as follows:
INPUT1 - Samsung DCB-B260Z (Generic SCART, Local Cable TV Service - http://www.comhem.se/downloads/instr...msungcb260.pdf)
INPUT2 - Pioneer DVR-520H (Via Profigold RGB SCART PGV7000, http://www.service.pioneer-eur.com/p...DVR-520H-S.pdf)
507XD Analogue Tuner (http://www.service.pioneer-eur.com/p..._PDP-507XD.pdf)
I have all these inputs set to exactly the same run-in settings, and I have noticed that INPUT1 is much brighter than the TV, which in turn is much brighter than via my DVR Tuner...
I cannot find any settings to change in the cable box, and the DVR setting are not so great / adjustable...
My questions is, if I use DVE to calibrate the screen (Obviously via INPUT 2), then I use these settings and apply them to my other sources they won't be the same - How can I ensure all sources are calibrated to the same 'visual configuration'?...
Also, according to both pioneer manuals, I must use INPUT2 for DVR, but this is not RGB In enabled, and the DVR is currently outputing via RGB. Should I change to INPUT3 (RGB In), is there any problem with doing this?
*Is SCART to Component Lead any better?*
Cheers all,
miceri
HiFi Primare I30, Primare CD31, Monitor Audio GS20, Enchantress XLR, MA Pureflow Silver, Grado SR80
Visuals Pioneer PDP-507XD, Pioneer DVR-520H, PS2
miceri is offline
Old 21-11-2006, 12:35 PM   #2 (permalink)
miceri's Avatar
Re: DVE On Multiple Inputs
After a bit more reading, I realise that it is mainly to use the DVE settings as close as possible on the other inputs, with a little adjustment by eye for differences.
Otherwise, it would be a full blown ISF calibration, with signal generators and the like!
I'll just settle for pretty good via DVD/DVE for now and wait for calibration when I move house / buy new DVD and AV Amp within the next 12-18months. No point in doing that now, never know - might add a VP at that point too...
miceri is offline
Old 21-11-2006, 12:35 PM   #3 (permalink)
miceri's Avatar
Kinda depressing when you have to answer you own posts.
miceri is offline
dve, inputs, multiple
Refbacks are On
Thread Thread Starter Forum Replies Last Post
pvr with multiple inputs???? DD3 PVRs and VCRs 8 19-09-2006 11:10 PM
Multiple HD Inputs LipUp LCD Televisions 11 08-03-2006 3:16 PM
need multiple RGB inputs! lordnoize Interconnects, Speaker Cables and Switches 3 04-08-2005 8:49 AM
LCD TV with Multiple Inputs milanlad LCD Televisions 0 19-06-2004 11:13 AM
help with multiple audio inputs please ispartacus75 Computer Systems 1 18-09-2002 10:15 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
