AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration
LinkBack Thread Tools Display Modes
Old 13-11-2006, 11:32 AM   #1 (permalink)
VirusKiller's Avatar
Thanks: Gave 68, Got 65
What kit is required for front projector calibration?
Simple question really. Let's say you wanted to D65 and grayscale calibrate your projector at home (with or without an external VP). What would you need, how much would it cost, and where would you get it from?
Never stop the action...
VirusKiller is offline
Old 13-11-2006, 3:15 PM   #2 (permalink)
Thanks: Gave 31, Got 206
Re: What kit is required for front projector calibration?
simply put :
You need some way to read the colour and brightness characteristics of the display. Either a hardware colorimeter or a usb sensor and some suitable PC based software.
The hardware sensor is usually very expensive : (over 5k) , a PC based system can be as expensive but there are also some cheaper options ( the Spyder2 sensor and Calman for example).
You need some way of modelling the characteristics of your display to give you an idea of how to proceed with adjustment. ( usually software).
You need reliable test patterns to provide a reference to read from (DVE , Avia ...I prefer Getgray for simplicity).
You need to be able to access the RGB bias and gain controls on the display : some have them available in the user settings , most require service menu access.( its not always possible to get access to RGB bias and gain controls on every display) The ae900 is quite good in this regard I believe. ( panasonic displays generally are in my experience).
You need to have some understanding of what it is you are adjusting. Its not rocket science but for the best results it helps to know exactly what you are adjusting for.
Mr.D is offline
VirusKiller (13-11-2006)
calibration, front, kit, projector, required
Refbacks are On
Thread Thread Starter Forum Replies Last Post
PC Based audio calibration kit Lakes_Puma Room Acoustics, Audio and Video Calibration 2 30-06-2006 12:11 PM
Front USB ports required JohnG Computer Systems 6 01-02-2006 1:56 PM
Which Projector required for shop front display?? kopfan DLP, LCD and D-ILA Projectors 0 19-01-2006 3:04 PM
Front Speakers Required forrestgump Speakers 0 10-02-2005 7:45 PM
Calibration issues/sytems input required Mr.D Room Acoustics, Audio and Video Calibration 8 26-11-2001 6:16 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
