AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Home Cinema Construction and Configuration > Room Acoustics, Audio and Video Calibration
LinkBack Thread Tools Display Modes
Old 10-11-2006, 9:45 PM   #1 (permalink)
Thanks: Gave 22, Got 10
Minimum recomended room size?
I am looking to change my garage into a cinema room the room size is only 1.9m x 4.74m.
Its the width that concerns me, will it be wide enough for good surround sound or will the fronts dominate the rears as its very narrow.
Any comments or experiences shared greatly received.
Dont want to spend a great deal of time and cash if its too small !!!
Panasonic Ax 100 projector, Arcam AVR300 , DV 79 , CD 82,
PMC DB1+ center,Quad 11L's,77 DS rears, SVS SB12 + sub
elliotjames is offline
Old 10-11-2006, 11:39 PM   #2 (permalink)
jonny round boy's Avatar
Thanks: Gave 0, Got 13
Re: Minimum recomended room size?
I'm no expert by any means, but I've read on here that the ideal ratio for a room is 2:3:5, for example 2m high x 3m wide x 5m long. Having said that, there's quite a lot of threads in the 'Home Cinema DIY' forum of people converting garages, which would seem to be around the size you're looking at.
I'd suggest you have a look on there, as I'm sure many of these people were in the same boat as you.
jonny round boy is offline
minimum, recomended, room, size
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Dedicated room, what size minimum philthyanimal Home Cinema DIY 0 19-10-2006 9:43 PM
New HT Room - Is there a minimum size? Paul_T Home Cinema DIY 3 03-08-2005 12:26 PM
Help with room size/speaker size and power. Pic inside>> GodtheDJ Speakers 1 03-06-2003 9:07 PM
Recomended Screen Size Sanyo Z1 / Sony HS10 karl DLP, LCD and D-ILA Projectors 0 15-01-2003 4:57 AM
Minimum Size room for 40"/44" RPTV? oreoboy13 CRT Televisions 1 08-01-2002 6:54 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
