02-11-2006, 11:19 PM
#1 (permalink)
Thanks: Gave 96, Got 56
cavity wall insulation
can having cavity wall insulation installed change the sound of a system?
03-11-2006, 11:43 AM
#2 (permalink)
Thanks: Gave 45, Got 202
Re: cavity wall insulation
It won't definitely change the sound of the system  , only if you change a component in your system.
What are you looking for? Getting rid of some vibrations, reflections?
03-11-2006, 8:50 PM
#3 (permalink)
yes,i see the point you made
what i should have asked was will it change the room accoustics?
04-11-2006, 8:11 AM
#4 (permalink)
Thanks: Gave 32, Got 170
It will change the acoustics (everything does), but the changes will likely be too small to hear.
Panasonic TH-46PZ81B, Arcam AVR350, Linn LK100, Naim NAP110, Quad L-ites, PS3, Samsung 850, Sky+, Humax 9200T, Panasonic E50, Harmony 1000, Pixel Magic HD-MB200, M-Audio Flying Cow DAC, Pronto TSU9600, Mac Mini, iMac
04-11-2006, 9:16 AM
#5 (permalink)
Thanks: Gave 110, Got 108
it will only change the room acoustics if you have a low quality plasterboard stud wall, if its brick, then it wont make a difference. If your wall is a plasterboard stud it could resonate at a frequency that interferes with the goings on in the room, leaving a big percieved hole in your bass, if the wall is brick it wont resonate at a high enough frequency to notice(high enough is relative here, im talking about 40hz kind of area).
If you want to make some panels to go on the wall to change the acoustics then thats easy, rockwool in frames, fabric covered carefully placed will do it
06-11-2006, 9:47 AM
#6 (permalink)
It will dampen the sound in a certain frequency range to the outside world and if you stuff it tight into the free space it will lower the vibrations of certain frequencies (self-resonance of the board) a bit.
Don't exepect a big difference unless you add mass (e.g. a second layer seamless fixed to the first) or change the sound reflections properties of the wall (e.g. ingrain wall paper)
